dens
DL 757 Across Atlantic, PTV?
Mon Jul 05, 2010 6:02 am
HI,
I'll be flying in 3 days from Zurich to JFK on DL 207, operated by a B757.
What's the inflight entertainement like? Are there any PTV? I tried to look at Delta's webpage but coudn't find anything for this flight.
Alitalia744
Mon Jul 05, 2010 6:36 am
Depends on the day.
Looking at DL.com it looks like:
Tues 7/6 is a 75E
Weds 7/7 is a 75A
Thurs 7/8 is a 75A
Fri 7/9 is a 75A
Sat 7/10 is a 75E
75E has PTVs at all seats.
75A has overheads only...
Some see lines, others see between the lines.
BMI727
Mon Jul 05, 2010 8:38 am
Quoting alitalia744 (Reply 1):
Those are AVOD by the way.
KingFriday013
RE: DL 757 Across Atlantic, PTV?
Tue Jul 06, 2010 1:59 am
Tues 7/6 is a 75E
Weds 7/7 is a 75A
Thurs 7/8 is a 75A
Fri 7/9 is a 75A
Sat 7/10 is a 75E
That's odd. The 75Es are the only planes capable of flying TATL flights. The 75As can't legally fly across the Atlantic.
The 75Es are the ex-TWA aircraft certified with ETOPS.
-J.
Tho' I've belted you an' flayed you, By the livin' Gawd that made you, You're a better man than I am, Gunga Din!
BMI727
Tue Jul 06, 2010 4:44 am
Quoting kingfriday013 (Reply 3):
What about the ex-NW birds? I don't think that those are the 75As (I thought those were the ex-ATA planes), but there are some ex-NW planes that are able to fly across the pond.
KingFriday013
Wed Jul 07, 2010 12:15 am
Quoting BMI727 (Reply 4):
I forgot about those! The ones that can fly trans-Atlantic/Pacific flights are some of the 5600-series 757s, which are newer than the 5500-series aircraft. I'm not sure what the story is with those regarding the interior, though.
-J.
Eirules
Fri Jul 09, 2010 8:58 pm
Are DL upgrading the other 752s so they all have PTVs or are they just leaving them as is? If so, is there a date set for their completion?
deltal1011man
Sat Jul 10, 2010 3:41 am
Yes 75A can do TATL flights. Delta has 8 75As, which are ex NW ETOPS birds. (read below)
those would be 75Vs, but they are also ETOPS and *could* do TATL flights.
Quoting kingfriday013 (Reply 5):
read below.
Ok so here is a Delta 757-200 key. Codes are what Delta uses.
757- 24F/162Y. CRTs. D Domestic
75X- 26F/158Y. PTVs. D Domestic/TCONs
75E- 16F/158Y. PTVs. D ETOPS/TATL and JFK-SFO/LAX
75V- 22F/156Y. CRTs. D ETOPS/Hawaii.
75N-22F/160Y. None N Domestic
756-22F/162Y. None N Domestic
75J-20F/162Y. None N ETOPS/Hawaii/intra-Asia
75A-6F/144Y. CRTs in Y and PTVs in C ETOPS. TATL/intra-Asia
If it has a D it was a DAL-S bird and if it has N it was a DAL-N bird.
SurfandSnow
Sat Jul 10, 2010 5:02 am
Quoting deltal1011man (Reply 7):
Any idea of how many of each type there are? Sounds like there must be a lot of those old NWA birds in desperate need of some IFE!
Users browsing this forum: OEM, redzeppelin and 1 guest
