MEACEDAR
FRA Connection Question
Wed Jul 21, 2010 12:20 am
Hey there a.netters,
I am going to be flying from BEY to MCO with a connection in FRA with my grandmother in a few weeks. I have about an 8 hour wait in FRA, so I was wondering if I should just book a hotel room for the 8 hours and rest comfortably or should I go to the business class lounge.
HT
RE: FRA Connection Question
Wed Jul 21, 2010 5:32 am
Most dayrooms only can be used from 0900h onwards; anything earlier would require you to purchase a whole night.
Just for a reference, Carat Hotel at FRA (with shuttle bus) charges 50 € for a double room (check in from 0900h, checkout until 1700h). Rates at other hotels should be similar ... (but I haven't checked rates of the hotel(s) immediately at the airport).
As I assume that you and your grandfather are on flights 3519 and 464, you only would be able to use a dayroom between 0900 and, say, 1100/1130h before having to retrun to the airport for your 1400h departure to MCO.
It really is a split decision here:
50 € for 2 persons giving them the option to sleep (if wanted) for 2 hours plus enabling them to have a shower is not a bad thing. Will make the 22-hour trip more bearable.
OTOH, if you have access to a lounge for free, you can enjoy free drinks & food there w/o having to leave the airport.
In case you would have to pay for lounge access, I probably would prefer the day room and get something to eat & drink in the airport supermarket before heading to the hotel.
-HT
MEACEDAR
Wed Jul 21, 2010 7:08 am
Well, we will be flying business class so access to the lounge should not be a problem. How are FRA's lounges?
HT
Wed Jul 21, 2010 1:01 pm
Quoting MEACEDAR (Reply 2):
Often filled to capacity. There even was some info going around lately, that they (= LH) would scan BPs in order to being able to redirect passengers to other Business Class lounges should one be filled.
The one in concourse A is conveniently located if your flight o MCO leaves from concourse A. Just step out of the lounge, up one escalator and passport control (IIRC, no new security check !).
-HT
