b6a322
Lufthansa A333 Seat 12A Question
Thu Nov 25, 2010 11:17 pm
Hey Anet,
I'm flying with LH Business class from JFK-MUC next month on the 25th. The equipment is showing as an Airbus A330-300, and I selected seat 12A from the Lufthansa website. However, I was looking at seatexpert today and the seat shows up highlighted in yellow (as does the other row 12 window), however, a mouse-over does not yield any drawbacks to the seat. The seat appears to be in the middle of the business class cabin, so I'm trying to figure out what kind of drawback there could be. I'm kind of tall at 6' 3.5" (and growing) so any inches taken away really count.
If anyone has any info on this seat or row from flying before, or just general seating advice, it would be great if you could post below. Thanks.
The content I post are my own thoughts, nothing more. :)
chootie
RE: Lufthansa A333 Seat 12A Question
Fri Nov 26, 2010 2:12 am
Hi B6322
Probably just marked in yellow because it is in the middle of the second(seperated by the toilets and galley) C/Cl cabin, and you may have to wait to be served.(usually begining in row 3 to the rear). Might mean that your meal choice is gone or when people are waiting for the toilet in front of row 10 they may disturb you.
Regardless, it should be a Fabulous flight!!!
N-JOY
chootie
Quokka
Fri Nov 26, 2010 2:44 am
Seatguru doesn't show any problems for row 12 for the A330-300 operated by KH. But if it is just the window seats that are showing up yellow, then it may be that the windows are misaligned and you may need to lean forward to get a view.
b6a322
Fri Nov 26, 2010 5:21 am
Quoting chootie (Reply 1):
Hopefully this won't be too much of a problem - I do intend to sleep as much as I can. Gotta do some major league auto-bahning after I arrive.
Indeed it should be! And I may even do my first trip report about it!
Quoting Quokka (Reply 2):
Its just the window seats, so that's probably it. On the plus side, the seat next to me (actually much of the row) is showing to be empty at this point, so maybe ill cheat and lean both seats back a little to get the other window
HT
Fri Nov 26, 2010 6:44 am
Quoting B6A322 (Thread starter):
I recalled that around that area a window is missing due to technical reasons.
Seatguru does not show it for the LH A333 but if you check for a DL A333 you get that info.
Have look:
The missing window #2 aft of door 2R is of no concern (lav), but the missing window #9 "is yours".
Photo © Marvin Meinel
Photo © Oliver Brunke
-HT
b6a322
Fri Nov 26, 2010 2:42 pm
Quoting HT (Reply 4):
Good catch! Thanks!
I assume that since it is business class, I will have another window closer to my seat (each seat has two or three windows if I recall correctly). As long as its not the window right next to where my head is, I think I'll be able to manage, seeing as it is a night flight.
TBloemink
Sat Nov 27, 2010 9:57 am
I don't see any yellow tags? Only at 10, thats because of the lavatories and galley.
Flown on: A300, A319, A320, A321, A330(-200,300), A380, B717, B737(-400,700,800,900), B747, B777(-200,300), B787-9, Embraer 170, Fokker 70
b6a322
Sat Nov 27, 2010 5:00 pm
Quoting TBloemink (Reply 6):
Seatguru does not show any yellow tags for row 12. On the other hand, Seatexpert shows a yellow tag on 12A and 12K.
TBloemink
Sat Nov 27, 2010 6:09 pm
Quoting B6A322 (Reply 7):
My fault, I thought he said seatguru :S
HT
Sat Nov 27, 2010 8:13 pm
Quoting B6A322 (Reply 5):
Correct. Should be 3 windows on LH's seat layout.
According to http://www.lufthansa.com/mediapool/pdf/95/media_871795.pdf it will be the most forwardly located window.
Downward views from row 12 will be obstructed by the wing;.
On a sector JFK to MUC, "sleeping" should have priority anyhow ...
-HT
b6a322
Sat Nov 27, 2010 10:45 pm
Quoting HT (Reply 9):
What a great PDF file! Its a shame more airlines don't have those for their aircraft!
Exactly. I plan on sleeping as soon as we get airborne. When all is said and done it is really not such a long flight, so every minute counts.
HT
Sat Nov 27, 2010 10:54 pm
Quoting B6A322 (Reply 10):
So, you will skip the evening meal service on board and will have had some bite while still on the ground then ?
To my experience, it often takes 2 hours before the meal service is finished on those evening flights out of the U.S. - 2 hours less of precious sleep ...
-HT
b6a322
Sun Nov 28, 2010 4:14 am
Quoting HT (Reply 11):
Yes. I will sample the food in the lounge. Something light like a soup with a salad will do - I don't need to feel bloated - just satisfied. Also, I only tested the drinks in the lounge the last time I passed through, so I want to try a different part of the Lufthansa experience.
This was my experience as well when I took the same flight (albeit it in an A340-300). Waiting for dinner is a mistake I won't make again!
However, I've also had this slow dining experience on Airberlin in business class, so it is more widespread than just Lufthansa. I'm not entirely sure what the reason for it is though.
Users browsing this forum: VC10er and 2 guests
