AR385
Help With LH 499 And 510
Fri Nov 26, 2010 5:31 pm
Flying on Monday Nov. 29 on LH 499 C MEX-FRA. I arrive in FRA on Tuesday Nov 30 and after a few meetings, I catch the LH 510 F to EZE that evening. Can someone tell me which 744s are scheduled to fly those sectors? Any other suggestions? Thanks, I appreciate it.
oly720man
RE: Help With LH 499 And 510
Mon Nov 29, 2010 4:35 pm
LH498 is 3.5hrs late leaving FRA according to the LH website. Should be leaving 17.45 local.
AR385
Mon Nov 29, 2010 4:59 pm
Quoting oly720man (Reply 1):
Thank you oly720man. How much time do you think they can make up in the air? 45 mins. to 1 hr? The schedule is to spend two hours in MEX before they turn around. Do you think they can cut time there too?
oly720man
Mon Nov 29, 2010 5:54 pm
Quoting AR385 (Reply 2):
Hard to say. All the recent flights have been 11:30hrs give or take 15 minutes so I can't imagine they'll be ably to catch up the best part of an hour unless the winds are particularly favourable.
http://flightaware.com/live/flight/DLH498
I'm not sure there's a lot to be saved in the 2hrs on the ground given the time to offload and then load up again. Is there a rush-hour at MEX? Some time may be saved if the plane isn't in a queue for departure.
And the plane is D-ABVA, from Libhomeradar.
2010/11/29 17:11 DLH498 DLH498 FRA-MEX D-ABVA Lufthansa B744
AR385
Mon Nov 29, 2010 7:02 pm
Wow, isn´t that the first 744 in LH´s fleet?
oly720man
Mon Nov 29, 2010 9:39 pm
Quoting AR385 (Reply 4):
It looks like it. Delivered in May '89. D-ABVB first flew in June 1988 but delivered Sept 1989.
Users browsing this forum: hinckley and 2 guests
