mrskyguy
LAX To Bordeaux - Any Suggestions?
Sat Nov 27, 2010 9:24 pm
I have a trip coming up to Bordeaux soon, and have never flown there before. I'll be departing from LAX, and was thinking about a few options, including flying to Paris and taking the high-speed through the countryside to Bordeaux.
Any suggestions?
"The strength of the turbulence is directly proportional to the temperature of your coffee." -- Gunter's 2nd Law of Air
HT
RE: LAX To Bordeaux - Any Suggestions?
Sat Nov 27, 2010 10:50 pm
What will be the seating class for this trip ? Eco or Business ?
Quoting mrskyguy (Thread starter):
Thru trains from Roissy (CDG) to Bordeaux appear to be infrequent in the early afternoon.
You'd be advised to check if train times match favorably with air arrivals (the flight you are looking into).
If you use AF 065 arriving at 1125h, your option would be TGV 05218 departing CDG2/Roissy 1337h arriving Bordeaux St. Jean at 1800h sharp, making it a 4h23min ride.
2 hours of layover and a 4.5-hour train ride after a redeye flight across the pond ? Hardly something I would fancy ...
Will you have plenty of luggage/baggage to drag along ?
How much more expensive would it be to fly AF all the way to BOD ? If you choose AF 065 and then AF 7624 you'll ariive at BOD at 1405h.
Taking a train from "downtown" Paris will mean even more hassle, as you first will have to take the RER to Paris Montparnasse.
I think I would prefer flying to BOD ...
-HT
goldorak
Sun Nov 28, 2010 12:24 am
I completely agree with HT. Just connect AF to AF in CDG
ajd1992
Sun Nov 28, 2010 1:08 pm
I would recommend just hopping an AF flight down to Bordeaux. A train ride with luggage is bad at the best of times, and if you've never done it before then it'll be my definition of hell. The flight from CDG to Bordeaux can't take more than 45 minutes anyway, way quicker than a 5 hour train ride.
FlySSC
Sun Nov 28, 2010 2:15 pm
If you really want to take the TGV (High Speed Train), then try it on you way back to CDG ...
From LAX to BOD you can try :
LAX. 3:25PM ----- AF065 (B772ER) ----- CDG. 11:25AM / 12:50PM ----- AF7624 ----- BOD 2:25PM
LAX. 6:30PM ----- AF069 (B77W) ----- CDG. 2:05PM / 4:00PM ----- AF7634 ----- BOD. 5:15PM
LAX. 9:40PM ----- AF073 (B772ER) ----- CDG.5:15PM / 6:35PM ----- AF7626 ----- BOD. 7:50PM
You have also som possibilities with BA or LH via LHR or FRA
oly720man
Mon Nov 29, 2010 10:20 pm
Quoting FlySSC (Reply 4):
The BA flights to Bordeaux are from LGW.
LHRBFSTrident
Tue Nov 30, 2010 12:35 am
There's also KL: LAX-AMS-BOD
I think a rare opportunity to fly a Fokker70, if you're into that kind of thing - although KL may have switched BOD services to the E190 by now...
but then AMS isn't too convenient if you want to take the train in one direction or the other.
FlySSC
Tue Nov 30, 2010 8:43 am
Quoting oly720man (Reply 5):
Correct. I forgot ... so forget BA. Connecting within LHR is already a nightmare ... connecting LHR/LGW is even worse !
Quoting LHRBFSTrident (Reply 6):
With the combinability fares, you can fly KL one way via AMS and AF the other via CDG if you realy wan to take the train ...
mrskyguy
Thu Dec 02, 2010 4:43 pm
Quoting HT (Reply 1):
It's Eco for me this time, I'm afraid.
Sounds like most of you are suggesting I toss the ideal of a train, as romantic as that sounds on paper. I will be carrying a solid chunk of luggage too.
HT
Thu Dec 02, 2010 9:28 pm
Quoting mrskyguy (Reply 8):
Then you should avoid using the train.
It is much more convenient to check that at home and retrieve at your final destination, especially if you have a (kind of) private transport at hand.
-HT
Users browsing this forum: vhtje and 2 guests
