02hilliert
Transfer Between Orlando Airports
Wed Jan 19, 2011 1:25 pm
Hi All,
I'm planning a possible trip to the US in June/July time, arriving in LGW-SFB, and then continuing on from MCO.
Does anyone have some suggestions for transfers between the two airports? Time is not too big of an issue, but cost is. I've been told a taxi would be up to $100 incl. tip, and I'm convinced that renting a car would be cheaper than that!! Any bus services from SFB to Orlando to MCO?
Next Up: Back to the US - Charlotte & Kansas City
einsteinboricua
RE: Transfer Between Orlando Airports
Wed Jan 19, 2011 2:05 pm
Why don't you arrive directly to MCO? Where is your final stop?
"You haven't seen a tree until you've seen its shadow from the sky."
747luvr
Wed Jan 19, 2011 2:31 pm
I live about 10 miles north of SFB, although i've never used their facility. There is no bus service btwn the 2 airports, car rental wouldnt make much sense once you factor the hassel, and time involved, not to mention, you'd prob only save $40 if that after taxes, and fees. Cab is probably the best. Had you flown into DAB (and i know theres no flights from LGW), there is a service that takes you from DAB to MCO via aprivate shuttle outfit.
exFATboy
Thu Jan 20, 2011 3:02 am
Quoting einsteinboricua (Reply 1):
Monarch, Thomas Cook, and Thompson all go into SFB from LGW, I'm presuming he's on one of those. Besides Allegiant, it's the cheap charters from the UK that are SFB's bread and butter.
Shuttle van services may offer a slightly cheaper alternative to a cab - AirportAbility (and that's a bit of an annoying name, no?) is the only one I could find quickly that specifically lists service from SFB to MCO It's $65, not including a 20% tip. (I'm not sure if the "gratuity" is mandatory or not, frankly 20% for a shuttle van sounds a little steep to me, and I'm usually a pretty good tipper).
Orlando Carriers lists a one-way between SFB and the hotels on I-Drive - slightly further away from SFB than MCO is - as $28 one-way from noon to 7PM, $50 the rest of the time, not including tip. They should be able to drop you at MCO, but I'd call or e-mail them and check first just to be sure...usually there's no restrictions on who can drop off at an airport, but you never know. If for some reason they couldn't or wouldn't take you to the terminal, you could have them take you to International Drive or somewhere on Semoran Blvd/SR 436. and then take the Lynx bus (#41 or #42) to the airport.
(Lynx is a regional service and apparently serves Seminole, but not the airport, the nearest stop is somewhere between 1 and 3 1/2 miles away, the Lynx site lists conflicting info. You could take a cab to the bus stop, I guess, as long as you can find out on the Lynx site exactly where the stop is. Sounds a bit like a pain in an unfamiliar city, especially if you have checked bags. But if you're traveling light and have plenty of time, you might check into that too.)
Disclaimer: Check carefully into stops, schedules, etc. if you try an option involving buses, public transportation in most of Florida leaves something to be desired. I make no guarantees...  Silly )
[Edited 2011-01-19 19:03:30]
02hilliert
Thu Jan 20, 2011 9:07 am
Quoting exFATboy (Reply 3):
Brilliant, thanks - i'll try those options first.
Flying in with Monarch. I'll be back two weeks later, flying in with Allegiant before returning to London on MON. So I don't have that problem again. Thanks guys...
Users browsing this forum: PatrickZ80 and 1 guest
