rw774477
Most Legs / Distance With A Single Flight Number?
Fri Mar 11, 2011 1:46 pm
WN 1655 looks like a good contender in terms on number of stops
HOU-MSY-BWI-ISP-MDW-DEN-SAN-OAK
What about distance - looks to something like NZ 0001 - LHR-LAX-AKL
sw733
RE: Most Legs / Distance With A Single Flight Numb
Fri Mar 11, 2011 3:25 pm
Quoting rw774477 (Thread starter):
WN definitely seems to be the expert on taking one flight number and crisscrossing the country 26 times with it.
Fri Mar 11, 2011 4:09 pm
Can one really book that one all the way from HOU to OAK with all those stops?
sw733
Fri Mar 11, 2011 4:29 pm
Quoting B747forever (Reply 2):
From my understanding, it would require actually calling Southwest and having them book it, because the website won't let you book something like that - it would just route you HOU-OAK nonstop or via 1 or 2 stops.
rw774477
Fri Mar 11, 2011 5:05 pm
It's good that WN doesn't charge per leg baggage fees !!!
wilco737
Fri Mar 11, 2011 5:55 pm
I don't remember the exact routing. But I was once one WestJet flight from YVC to YYC and it will continue with a couple stops all the way to St. Johns. But don't know how many stops anymore. Too long ago.
wilco737
PlymSpotter
Fri Mar 11, 2011 6:43 pm
Wideroe have some similarly long routes with multiple stops, maybe even more than Southwest.
Dan
Fri Mar 11, 2011 8:04 pm
Quoting sw733 (Reply 3):
Yeah, I know I looked it up. Wonder though what they would charge for that route. Might even call them to ask.
citationjet
Fri Mar 11, 2011 10:08 pm
Most legs for a single flight - historical:
Braniff schedule for September 16, 1946 shows the follow single flight operated by a DC-3:
Braniff flight 53 routing:
Chicago > Moline > Burlington > Kansas City > Topeka > Wichita > Ponca City > Oklahoma City > Dallas > Fort Worth > Waco > Austin > San Antonio > Laredo
Lunch was served on the Topeka to Kansas City leg. A snack was served Waco to Austin.
The scheduled ground times were 5 minutes, except for Dallas which had 13 minutes.
The flight left Chicago at 8:50 am and arrived Laredo at 9:08 pm.
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
RJLover
Fri Mar 11, 2011 11:11 pm
In the distance category.....
AC33 YVR-SYD (or AC34 SYD-YVR-Last Flight(s): YHZ-YYZ-YVR-YYJ // YYJ-YYZ-YHZ Next Flight(s):
RJLover
Fri Mar 11, 2011 11:15 pm
Quoting RJLover (Reply 9):
AC33 YVR-SYD (or AC34 SYD-YVR-Edit Post ]
Since my first post got all weirded out....
AC33 YYZ-YVR-SYD (or AC34 SYD-YVR-YYZ). At 8552NM it doesn't beat NZ1, but it sure is up there!
Viscount724
Sat Mar 12, 2011 3:20 am
Canadian regional carrier Air Inuit has some Dash 8 flights with as many as 6 stops between Montreal and remote communities in northern Quebec. One has an elapsed time between YUL and the last stop of over 10 hours.
hoons90
Sat Mar 12, 2011 4:05 am
KE061 ICN-LAX-GRU is at 19554km, which is 306km longer than NZ's AKL-LAX-LHR.
The biggest mistake made by most human beings: Listening to only half, understanding just a quarter and telling double.
kiwiandrew
Sat Mar 12, 2011 8:05 am
IIRC correctly UTA used to operate a service from CDG to LAX the long way around , didn't they ? Something along the lines of CDG-BAH-SIN-JKT-SYD-NOU-AKL-PPT-LAX ( I think that CMB also figured in the route at one time ? or did they break it up into separate flight numbers ?
BNAOWB
Sat Mar 12, 2011 12:39 pm
Quoting HOONS90 (Reply 12):
Air Austral 771 CDG-RUN-SYD-NOU is 20,568 km (11,106nm)
kiwiandrew
Sat Mar 12, 2011 9:11 pm
Quoting BNAOWB (Reply 14):
Thanks for that , I didn't realise that it had a single flight number all the way from CDG - I wonder if anyone ever does the flight right through from beginning to end ... there are easier ways to get from CDG to NOU ( though not with the same aircraft/flight number all the way )
BNAOWB
Sat Mar 12, 2011 11:58 pm
Quoting kiwiandrew (Reply 15):
Yes. It looks like CDG-NRT/KIX-NOU on AF/Air Calin would be a quicker routing (though less interesting). It would be fascinating to find out what percentage of the CDG-RUN passengers on Air Austral continue onto SYD or NOU. In the unlikely event that the vast majority continue to NOU, it would seem that Air Austral could do CDG-RUN-NOU since the RUN-NOU distance is just over 6000nm and they use the 777-300ER for this route. But, SYD is probably essential for the route's success.
Viscount724
Sun Mar 13, 2011 12:38 am
Quoting kiwiandrew (Reply 13):
I think the flight number changed at least once (maybe twice).
timz
Tue Mar 15, 2011 11:00 pm
Quoting CitationJet (Reply 8):
Pretty sure the record is more than 13 legs.
citationjet
Wed Mar 16, 2011 1:19 am
Quoting timz (Reply 18):
I would agree, however no one has posted one yet....
