monorail
Location Of Door Plugs On CO's 739ER
Fri Apr 15, 2011 2:51 pm
I've got an upcoming trip on a Conty 739 and I'm a bit concerned I landed in the row next to where the plug is located if an -ER version shows up.( There's no problem if a 739A shows up instead.) Does anybody know the exact rows where the plug is located? There aren't nearly as many missing windows there as over the wing, but they're still misaligned enough that you may be forced to lean far to look out.
Photo © Wladimir Castro
I'm in 30F right now. The only remaining vacant windows are in the very back row or 2, which I'd rather avoid.
I've tried Seat Guru and all of its knockoffs and Google and wasn't able to find an answer.
Playoffs? Don't talk about playoffs!
roseflyer
RE: Location Of Door Plugs On CO's 739ER
Fri Apr 15, 2011 10:06 pm
Yes you hit it. Row 30 is where the door plug with the standard window is.
monorail
Sat Apr 16, 2011 10:28 pm
Quoting RoseFlyer (Reply 1):
Yes you hit it.
Blast. Well I'm going to change my seat right now then. Thanks for the help!
ata757300
Sun Apr 17, 2011 12:26 pm
does anyone have a picture of the plugged exit interior
Users browsing this forum: bohica, kenanc, Scinfaxi and 2 guests
