30 MIN Connection At LCY?
Tue May 10, 2011 5:46 pm
I wonder if 30 minutes between to international BA flights is enough at LCY? Looking to fly ARN-LCY-MAD.
Any help is appreciated.
EDIT: Will I have to re-clear security again?
[Edited 2011-05-10 10:49:20]
nqyguy
RE: 30 MIN Connection At LCY?
Tue May 10, 2011 6:26 pm
Is BA selling the ticket or are you self-connecting on two tickets?
Also, baggage or not? 30 minutes is risky.
Tue May 10, 2011 6:29 pm
Quoting NQYGuy (Reply 1):
BA is selling the ticket and I will not have any baggage.
Tue May 10, 2011 6:33 pm
I did connection in 15 minutes at LCY from VG to VG flights (now Cityjet). But that doesn't matter on the airline actually.
Security can be a bit busy at some moments, but usually it's very fine and you'll be in the queue for security within a few minutes after your arrival.
Although, beware of delays... Can you risk that short time? Or if it's on one ticket you do not have to worry, BA will take good care for you then.
nqyguy
Then yes, that sounds possible. At least you're covered if you miss it- there is a flight connections channel at LCY and AFAIK there is no reason why you couldn't use it.
Tue May 10, 2011 6:38 pm
Quoting airbuseric (Reply 3):
So I will have to clear security again?
sw733
Tue May 10, 2011 6:58 pm
Quoting B747forever (Reply 5):
Yes, you should have to clear security again, just like if you were connecting at LHR.
Tue May 10, 2011 7:01 pm
Quoting SW733 (Reply 6):
Yeah, I see. Have connected through LHR quite a few times and the lines can be long. Hopefully it is better at LCY.
Tue May 10, 2011 9:10 pm
Quoting B747forever (Reply 7):
It's better for sure, plus the staff is helpful to accomodate you in front of the lines when neccesary to catch a flight (experienced myself during a more busy moment).
Of course you can always make sure to be seated close to the exit on the inbound flight, so you create a few more minutes for yourself
Viscount724
Thu May 12, 2011 12:25 am
One of the disadvantages of connecting in the UK (which isn't part of the Schengen area) is the need to clear security twice. If you connected at AMS/FRA/CDG/ZRH/BRU or anywhere else in the Schengen area you would only have to clear security once at ARN. I made a 15 minute connection at AMS a few weeks ago when my inbound flight was late. I would never have been able to do that if there had been a second security check.
Even at LCY a 30 minute connection is risky if only due to the possibility that your arriving flight is late.
