Jackbr
United 767 Domestic Routes
Wed May 11, 2011 12:00 am
Where do United currently operate their 763s on domestic flights?
How many aircraft in the fleet are actually in the domestic configuration?
jetblue777
RE: United 767 Domestic Routes
Wed May 11, 2011 12:13 am
ORD-DEN-ORD sees alot of widebodies (763s and 772s)
It's a cultural thing.
Jackbr
Wed May 11, 2011 12:20 am
I believe this thread should stay in the "Civil Aviation" forum where literally every other route/aircraft config thread I've made has stayed. Nothing in this thread has anything to do with "preferences" or "polls"
warreng24
Wed May 11, 2011 12:34 am
Quoting Jackbr (Thread starter):
The 3-class aircraft are used primarily for International flights out of ORD and IAD. They can sometimes be found on domestic re-positioning runs between ORD-IAD.
The 2-class aircraft are primarily used for SFO/LAX/DEN-HNL routes. The 2-class also operates regularly SFO-IAH-LIM-IAH-SFO. Most of the 763's assigned to hub-to-hub routes are 2-class aircraft.
PMUA has 14 763's in the 2-class domestic configuration.
IAHFLYR
Wed May 11, 2011 2:29 am
They now fly a B763 on a SFO-IAH route that continues on to LIM, then returns to IAH-SFO in the morning.
united319
Wed May 11, 2011 5:04 pm
From Today's Schedule: Note that the flights are listed one-way only since most of them are not round-trip 767 flights.
SFO-ORDx2
SFO-IAD
SFO-DEN
SFO-IAH
SFO-HNL
SFO-OGGx2
LAX-IAD
LAX-DEN
LAX-HNLx2
LAX-OGGx2
DEN-ORD
DEN-SFO
DEN-LAX
DEN-HNL
DEN-OGG (operates SAT only)
ORD-SFOx2
ORD-LAX
ORD-IAD
IAD-ORDx3
IAD-LAX
HNL-SFOx2
HNL-LAXx2
HNL-DEN
OGG-SFOx2
OGG-LAXx2
OGG-DEN (operates SAT only)
IAH-SFO
It's Time To Fly
Jackbr
Wed May 11, 2011 9:37 pm
Thanks for the replies guys
Is there ever any 763 presence in JFK or LAS?
jetblue777
Wed May 11, 2011 10:40 pm
Quoting Jackbr (Reply 6):
JFK is exclusively all-757 (P.S.)
But once in a while they use a 763 as a replacement.
Photo © Cary Liao
Jackbr
Fri May 13, 2011 3:20 am
Thanks for your replies guys
Do the 3 class aircraft ever appear on domestic routes as equipment subs?
jetblue777
Fri May 13, 2011 11:43 am
Quoting Jackbr (Reply 8):
The 763 subbed for JFK is definitely a 3-Class A/C. Also, this summer the 3-Class 763 flies between ORD and DEN (usually in the early morning, 7 or 8)
united319
Fri May 13, 2011 5:10 pm
All the routes I listed earlier in the threat are 767 routes. Some of those are flown on 67I aircraft. I do know that you wont see a 67I on Hawaii flights.
It's Time To Fly
roseflyer
Fri May 13, 2011 5:32 pm
Yes 3 class airplanes do sub on domestic routes. For example, there are no spare 2-class 777s. If one goes tech or gets extended maintenance, the only plane UA can sub is a 747, so you will sometimes see SFO-HNL being operated with 747s.
Out of the UA fleet, the most spares are with the Airbus fleet. I believe there are 6 spare Airbus narrowbodies in the network on an average day (compared with 4 spare 757s), so adding segments with them is the easiest.
Quoting JetBlue777 (Reply 9):
If a PS airplane needs to be subbed out the preference is to use a 3 class 767. The configuration goes from 12-26-72 to 6-26-151, so there are a lot of extra economy seats. F is rarely full, so usually there are not downgrades. However the summer schedule only has 1 spare 3-class 767 our of the 21 3-class 767s, so the chances of that happening are low.
PS planes will occasionally be seen swapping for A319s on LAX-SFO routes.
united319
Sat May 14, 2011 3:40 am
Quoting RoseFlyer (Reply 11):
I've been on a 57P (PS) from IAD-ORD and from ORD-SFO. It was nice. 3J for both flights!
It's Time To Fly
LY777
Sun May 15, 2011 10:18 am
Do UA 763 Domestics have PTVs?
roseflyer
Sun May 15, 2011 5:55 pm
Quoting LY777 (Reply 13):
No. Only the international 767s have PTVs. They have them in all classes with the full AVOD system and new first and business seats.
LY777
Mon May 16, 2011 9:34 am
Quoting RoseFlyer (Reply 14):
Great.
The 763s that are used on the LAX-HNL are considered as international or Domestic?
What about their 777s? Do they all have AVOD?
Jackbr
Tue May 17, 2011 6:52 am
Quoting LY777 (Reply 15):
Domestic 767s to HNL, no PTV
