aa777lvr
DL17/DL16 Ever Weight Critical?
Sat May 21, 2011 2:00 am
I am curious if anyone knows if DL's LAX-SYD (#17) and/or SYD-LAX (#16) ever incurs a weight penalty on the B777LR this time of year? I have been checking loads for non-reving and am curious before I get my hopes up.
-AA777LVR
abq707
RE: DL17/DL16 Ever Weight Critical?
Sat May 21, 2011 2:09 am
I could be mistaken and will most likely be corrected, but my understanding is that the weight for these two hauls are controlled by DL managing frieght/cargo making the trip.
First flight TWA 707 ABQ to BWI 1964
goboeing
Sat May 21, 2011 2:20 am
Quoting abq707 (Reply 1):
Right, he's asking if, after they load the plane, there is weight left over for non-revs since sometimes there isn't on the long routes with a lot of cargo.
aa777lvr, that route is on the weight restriction list so I'd have a legitimate backup plan in mind. Everyone I know who's non-revved that route using Delta has gotten a seat though. I don't think it's as bad as some other routes.
aa777lvr
Sat May 21, 2011 2:32 am
Quoting GoBoeing (Reply 2):
Correct-a-mundo! I know non-revs are last priority after revenue passengers, cargo/freight. I know specific weight and balance is dependent on fuel (weather forecast) and cargo. I am just curious how often non-revs have gotten left behind in either direction due to a weight restriction even if their are open seats on the aircraft.
Thanks for any help,
-AA777LVR (and a DL777LVR)
Transpac787
Sat May 21, 2011 2:40 am
Quoting aa777lvr (Thread starter):
Yes, they will occasionally become weight critical on the route. It's not so much an issue of range and fuel but far more-so an issue of the aircraft reaching MZFW given (what I'm told are) high cargo volumes and weights carried.
SYD is easily within range of the airplane, it just seems it's hit or miss if they have the extra payload capacity. As the other posters have said though, the flights seem to routinely take nonrevs when the seats are available. Just be advised that the route can and does go weight critical from time to time.
indiansbucs
Sat May 21, 2011 3:01 am
Can the route be done with an 777ER?
GSPFlyer
Sat May 21, 2011 4:42 am
Of course the 77L has some restrictions, but I am pretty sure it only has to stay under its max. takeoff weight. I think its range is between 7,000nm and 8,000 nm at max. takeoff weight (anyone know exact #'s), and LAX-SYD is 7,488 statue miles (Great Circle).
Quoting indiansbucs (Reply 5):
I think UA has subbed an -ER on the route before.
Thenoflyzone
Sat May 21, 2011 5:01 am
Quoting GSPflyer (Reply 6):
it's around 7,600 nm at MZFW and MTOW. LAX-SYD is 6,507 nm.
Yes, but not at MZFW. A 772ER will have to take a payload cut up to 30-40,000lbs in order to operate LAX-SYD.
Thenoflyzone
[Edited 2011-05-20 22:28:37]
us Air Traffic Controllers have a good record, we haven't left one up there yet !!
Transpac787
Sat May 21, 2011 11:55 am
Yes, albeit very poorly.
They have not.
They used to fly LAX-AKL with 777 but have never sent them to SYD.
Users browsing this forum: AirIndia and 1 guest
