kl911
Madrid, Connecting Time At T1
Wed Aug 03, 2011 7:23 pm
Hi all,
As many of you know I'm a die hard LCC flyer. But on Nov 13, a Sunday, I will have to connect between FR and W6 and will have 1 hour 45 minutes for it. Normally not a problem since I use small airports but MAD is in a different league.
How busy is T1 on sundays, and assuming FR is on time which it almost always is, do i have enough time?
I will be flying ACE MAD BUD
KL911
[Edited 2011-08-03 12:24:45]
kl911
RE: Madrid, Connecting Time At T1
Wed Aug 03, 2011 7:25 pm
Airport codes didnt show properly, but its ACE MAD BUD , first Ryanair, then Wizzair
migair54
Wed Aug 03, 2011 7:30 pm
It shouldn´t be a problem, usually it´s very fast. Another thing is if you need to go to T-4, but T-1, T-2 and T-3 are very close.
kl911
Wed Aug 03, 2011 7:45 pm
Thanks, both operate from T1 I believe.
777jaah
Wed Aug 03, 2011 8:33 pm
Quoting kl911 (Reply 3):
You'll be fine. As migair54 said, it would be a totally different thing if you needed to transfer to T4.
Next flights: AV BOG-ADZ-BOG, AV-UA BOG-IAD-ORD-IAD-BOG, BOG-FLL-BOG, LA BOG-MIA-BOG J
Thu Aug 04, 2011 8:33 pm
If you have no bags to check and if you preprint your onward boarding pass you'd even be able to remain airside (in transit) saving time to go to arrivals, back to departures and reclear security. If there is no delay, you should be fine. However if you have time and a longer connection is possible price and schedule-wise, I would probably go for a longer connection, just to be on the safe side (you never know...)
Maverick623
Thu Aug 04, 2011 11:07 pm
Quoting kl911 (Thread starter):
Plenty of time. Just the other week it took me 40 minutes to go from T2 (UX), to T1, get rebooked for a US flight, check in, and clear security.
"PHX is Phoenix, PDX is the other city" -777Way
kl911
Fri Aug 05, 2011 10:54 am
Thanks guys!
I have a second option, that is going ACE - MAD - FCO - BUD with Ryanair, Easyjet and Wizzair. connections times will be 5 and 3 hours, so a bit more safe. You never know the delays..
I assume Easyjet is using T1 as well? And does anyone know which terminal in Rome Easyjet and Wizzair use?
Users browsing this forum: gabrielchew, lollyj, RamblinMan and 18 guests
