dampfnudel
Do Americans Pay Higher Fares On Lufthansa?
Sat Aug 13, 2011 2:46 am
I was thinking about flying from JFK to FRA next month to visit family. I checked out Lufthansa's USA site and got $926 as the lowest fare for travel on 21 September 2011, JFK-FRA, coming back on 11 October 2011. I got a similar amount or higher for travel a week or two later. I noticed that various fees, surcharges and taxes added up almost to $600. When I checked the German site from LH, I got back 555 euros which at the current conversion rate is $790. That's $136 per person less if your travel originates in FRA. Now unless the conversion app I just used made an error, did I miss something or do Americans generally pay more than their German/European counterparts for transatlantic flights?
Any ideas on other sites I could try? I would prefer to fly out of JFK on LH. Delta is the same price, uses a B757 (I have a preference for a wide-body) and Singapore is not much cheaper with the inability to book seat assignments, unless perhaps you need to join KrisFlyer to do so.
A313 343 B703 722 732 733 73G 738 741 742 744 752 762 76E 764 772 CR9 D10 DHH DHT F27 GRM L10 M83 TU5
AA AI CO CL DE DL EA KL LH N7 PA PQ SK RO TW UA YR
Airvan00
RE: Do Americans Pay Higher Fares On Lufthansa?
Sat Aug 13, 2011 3:25 am
Yes, to cover the cost of rebuilding German cities after the war  .
Seriously, the cost of international flights have always been different depending on origin point. For a long time London-Sydney London flights were cheaper if booked from the London end. Similarly USA to OZ were always cheaper from the USA end. It is what the market will bear, sometime there is more demand in one direction than the other.
Viscount724
Sat Aug 13, 2011 3:39 am
It's rare for international fares to be identical in both directions. Fares are set to reflect the local market and competitive situation. The very weak euro exchange rate currently is another factor.
dampfnudel
Sat Aug 13, 2011 4:51 am
Quoting Viscount724 (Reply 2):
I know that international fares are rarely identical in both directions, but the difference was never as dramatic as it is now, at least not 7 years ago when I last flew to Frankfurt. Oh well, maybe I can dream tonight of dollar-euro parity and $30 a barrel oil (unlikely of course). For some reason, spending nearly $1,000 per ticket to fly economy between New York and Frankfurt in October doesn't sound right to me and I've flown that route close to 30 times since I was a kid during the 70s/80s.
ag92
Sat Aug 13, 2011 4:55 am
Quoting dampfnudel (Reply 3):
Check out SIN-DEL, about a few years ago
Singapore - Delhi - Singapore -> S$1,300 all in in Y
Delhi - Singapore - Delhi -> S$700 all in in Y
Same route, same flights and same airline. One just originates in Singapore and the other in Delhi
In fact it was so cheap, that often Delhi - Singapore - Delhi could be had for Business on SQ for slightly more than SIN-DEL-SIN and that's what all the frequent flyers on the route did, ticket it DEL-SIN-DEL despite living in SIN
dampfnudel
Sat Aug 13, 2011 5:08 am
Quoting ag92 (Reply 4):
Wow, maybe I shouldn't complain about the $136 price difference bet. what Germans pay and what Americans pay. Besides, Lufthansa probably needs to do this to convince Germans and others that it's worth going through the crap that the TSA puts airline passengers through as well as the enhanced screening by US customs.
charliecossie
Sat Aug 13, 2011 7:37 am
You can do it on BA for under 800 leaving from and returning to JFK or 750 leaving from newark and returning to JFK.
fxra
Sat Aug 13, 2011 7:54 am
About 10 years ago I was looking for flights inside Australia, I think SYD-CNS return, and wanted to fly Qantas. Shopping online, I found that prices on qantas.com (the US based website) were significantly more expensive than buying on qantas.com.au for the same flights. Didn't even bust me when I put in a US address at purchase.
Visualize Whirled Peas
FlyingHollander
Sat Aug 13, 2011 10:48 am
$1000 USD sounds horrible, but converted to €700 it isn't bad.
But it makes sense that flights to NY are cheaper as it is a tourist destination from Europe, FRA however isn't at all a tourist destinations.
If it ain't Dutch, it ain't much.
Sat Aug 13, 2011 2:31 pm
Furthermore, even if the fare in a booking class would be the same no matter which direction you travel, then availability could be different. i.e. on your travel date JFK-FRA only available in a high (and expensive) booking class, let's say H, but the other direction FRA-JFK in S and therefore much cheaper...
DTWLAX
Sat Aug 13, 2011 5:21 pm
I am assuming you want to say passengers would ticket DEL-SIN-DEL even when they wanted to fly SIN-DEL?
I am not sure how they could do that: does the ticket not get cancelled if you miss the first leg?
And what would they do for the return flight to SIN?
[Edited 2011-08-13 10:23:04]
DTWLAX
Sat Aug 13, 2011 5:24 pm
something
Sat Aug 13, 2011 11:13 pm
If you are price-sensitive, I suggest you look at secondary markets other than FRA. You can find JFK-DUS-JFK on Air Berlin for about €550 on the dates you quoted. Renting a car at DUS and dropping it off at FRA, including insurances and gas shouldn't cost more than €70. Depending on the number of travellers, the train might be the cheaper alternative.
..sick of it. -K. Pilkington.
Viscount724
Sun Aug 14, 2011 2:31 am
Quoting DTWLAX (Reply 11):
No, I think ag92 means that for passengers who regularly flew SIN-DEL-SIN they would buy a one way ticket SIN-DEL. Then from that point on they would purchase DEL-SIN-DEL tickets, using the DEL-SIN sector to return home and the return sector of that ticket for their next SIN-DEL outbound flight. In that way they benefit from the lower price levels from DEL and they're still using all their tickets in sequence.
Users browsing this forum: AH45 and 1 guest
