flySFO
United Won't Let Me Check In For UA926 Tomorrow?
Mon Sep 05, 2011 5:34 am
I'm flying SFO-FRA tomorrow (9/5) on UA926 and the online check in link leads to a page that is titled "flight status" and reads,
"Online check-in for your flight is not currently available. Please try again later or check in with a United Representative or at an EasyCheck-in® kiosk at the airport." Any UA insiders know why? Is the flight cancelled perhaps, or might this be an individual matter having to do with my ticket information?
Any help would be greatly appreciated.
fca767
RE: United Won't Let Me Check In For UA926 Tomorro
Mon Sep 05, 2011 5:58 am
Quoting flySFO (Thread starter):
When i did an international flight it happened to me with another airline.
aznmadsci
Mon Sep 05, 2011 6:01 am
Have you checked in online for a UA international flight before? If not it may be a passport issue.
Maverick623
Mon Sep 05, 2011 6:33 am
There's probably some sort of issue with your passport or APIS data. I wouldn't sweat it... a simple syntax or capitalization error can cause it. Did you book through United.com?
"PHX is Phoenix, PDX is the other city" -777Way
hiflyer
Mon Sep 05, 2011 6:51 am
APIS possibly or UA may be changing either aircraft type or configuration of your aircraft which is more probable. The fact it said try later leads me to suspect the second.
Mon Sep 05, 2011 12:15 pm
It has happened to me also, though it was BA (LAX-LHR). Showed out later at the airport that I was upgraded because the flight was overbooked in Y.
genybustrvlr
Mon Sep 05, 2011 5:07 pm
UA does this randomly for both international and domestic flights. It's a security procedure, forcing you to check in at the counter where they perform an enhanced ID check. This has happened to me twice: 1st time LGA - ORD, 2nd time SFO - YVR. It's horribly annoying and limited to UA as far as I'm aware. The ticket agent guessed that this procedure is applied to less than 5% of passengers. Given how much time I spend on UA, I think it could be much less than 5%.
Mon Sep 05, 2011 6:05 pm
Quoting B747forever (Reply 5):
This has happened to me as well, on BA LHR-JFK. It was because, even though our infant had an approved ESTA, we hadn't filled out the APIS - I thought I had, but hey. (no upgrade for us   )
jetblue777
Mon Sep 05, 2011 7:19 pm
Quoting hiflyer (Reply 4):
Most likely.
I flew DEN-ORD last month, it was scheduled to be on a 777-200 with the old configuration, 24 hours before the flight, it said that I could not check in etc. Around 10-12 hours before departure, they finally let me check in and apparently our aircraft was swapped with the new international 777 config. They also upgraded me to E+. BTW, it was N773UA which was also scheduled to fly to FRA after our flight.
I just checked via UA's app, and you're flying on the new config. 777-200! Reg is N784UA
Photo © Dmitriy Shapiro
[Edited 2011-09-05 12:26:51]
It's a cultural thing.
flySFO
Mon Sep 05, 2011 8:34 pm
Thanks everyone for the help! jetBlue 777, how do you check stuff like this? I have always wondered...
jetblue777
Mon Sep 05, 2011 9:42 pm
Quoting flySFO (Reply 9):
I used UA's very cool app. Just type in your flight number under Flight Status, then it's gonna show you a bunch of information. In the bottom it says, Aircraft #
I don't know how you do it for other airlines though...
photo (8)
photo (9)
It says aircraft #2884 which is N784UA.
photo (10)
Then here's another clue: The Seat Map
Users browsing this forum: AussieCanuck92, PSAjet17, seat1a, Wednesdayite and 7 guests
