PHKLM
Connecting In IAH
Mon Oct 03, 2011 6:28 pm
Is it possible to stay air-side when connecting in IAH from Terminal C (arrival) to Terminal D (departure)?
RamblinMan
RE: Connecting In IAH
Mon Oct 03, 2011 9:47 pm
Yes. IAH has 2 tram systems, one inside security and one outside, but to go from C to D I'm pretty sure you can just walk.
fshplns
Mon Oct 03, 2011 11:16 pm
If you are arriving into IAH into one of the gates in the north half of C concourse, D concourse starts connected to C concourse on the north half. D1 thru D3 are connected to C concourse, D4 and above are still connected but further walk. If going out of D6 and higher, it would be easier to take the shuttle train inside security(connects to A, B, D, and E)
IAHFLYR
Tue Oct 04, 2011 11:35 am
Quoting fshplns (Reply 2):
Nah, by the time you find the above ground train on the north side of Terminal C might as well keep walking down past D6, it is good exercise anyway!!
Quoting PHKLM (Thread starter):
You may find yourself arriving Terminal E as well which also is connected to Terminal D and very easy to access the D6-D12 gates.
Take a look at the link:
http://www.fly2houston.com/iah-terminalMaps
PHKLM
Tue Oct 04, 2011 3:00 pm
Thanks for the clear reply!
IAHFLYR
Tue Oct 04, 2011 3:30 pm
Quoting PHKLM (Reply 4):
Not sure how clear, but it is very very simple once you look at the joint and walk it.
fshplns
Wed Oct 05, 2011 11:15 pm
Thank you IAHFLYR, I very rarely use D gates anymore since E was built
Users browsing this forum: GaryDay, Mr AirNZ and 1 guest
