n88kb
LH Cruising Speed Question
Tue Oct 04, 2011 10:55 am
Hi everyone,
The picture below prompted me to ask if LH tend to cruise slower than other airlines. A few years ago I was on a BA 777 crossing the Atlantic to JFK and we passed a LH 343 like it was standing still. It was a little higher than us like the LH 744 in the picture. I know there alot of variables that determine cruise speed and was wondering if this a coincedence or does LH actually fly slower.
N88KB
Photo © Christos Sikoutris
[Edited 2011-10-04 03:56:39]
LY777
RE: LH Cruising Speed Question
Tue Oct 04, 2011 2:42 pm
The 744 has a cruising speed of 0.85
The 777, mach 0.84
The A343, mach 0.82
this is why you went faster
SASMD82
Tue Oct 04, 2011 3:17 pm
Are you sure this is an A340-300? I think it is a LH 747-400. The KL machine might had to gain some extra speed to comensate some delay. Maybe the LH bird departed from FRA before their actual departure time and did not have to fly at their maximum cruising speed. A lot of factors determine an aircraft's speed.
Both the A340s as well as the A330 fly slower than the Boeing 747 and 777.
Speedbird741
Tue Oct 04, 2011 8:12 pm
Quoting n88kb (Thread starter):
Just a coincidence. Optimal cruise speeds and altitudes are a function of many variables that range from cost index, to weight, to winds. Further, potential departure delays could prompt crews to select higher cruising speeds.
That's generally the case given the A340s smaller typical cruise speed. I'd take the A340 over the 777 any day though
Quoting LY777 (Reply 1):
It is a 744 and the OP did mention that.
Speedbird741
Boa noite Faro, Air Portugal 257 climbing flight level 340
wilco737
Wed Oct 05, 2011 3:55 am
The A343, mach 0.82
Due to the high fuel costs the cruise speeds got reduced now. We usually fly 0.84 on the 744 and the A340 usually only 0.80 or 0.81. That's why it is pretty easy to overtake an A340
wilco737
rduguy
Wed Oct 05, 2011 4:44 am
Quoting SASMD82 (Reply 2):
N88KB is saying that this picture reminds him of something that happened with him in the past. But is just using this picture is an example. He clearly states a valid question, in which he is wondering if LH overall, on all a/c has a lower cruising speed.
wilco737
Wed Oct 05, 2011 8:46 am
And it could be that one airplane was ahead of schedule and reduced the speed to save more fuel and the other was late and was doing M0.87? Could happen as well.
wilco737
LY777
Wed Oct 05, 2011 11:28 am
Last year, I flew CDG-TLV on a LY 772. A Sun d'Or 752 performing the same route took off at least 5 minutes before us.
Finally, we landed 5 minutes before the Sun d'Or flight!
This is due to the different cruising speed (mach 0.84 for a 772, mach 0.80 for a 757)
wilco737
Wed Oct 05, 2011 1:31 pm
Quoting LY777 (Reply 7):
I overtake the 340s, 330s, 767s all the time with the 744  Only the 777 is sometimes difficult to beat when they do 0.84 and we do 0.85 or 0.86, then it takes a lot longer.
wilco737
SASMD82
Wed Oct 05, 2011 3:30 pm
On the contrary, I flew a A346 of LH on the FRA-ICN leg and we overtook a company B744 (FRA-BJS).
The 747 left the gate (which was next to us) 2 minutes earlier and took off just before us. When we passeed WAW, we flew next to each other (2,000 or 3,000 feet below us) and by the time we passed Minsk we obtained a significant gain. After we passed Moscow, we were not able to see the 747 anymore (sunset).
wilco737
Wed Oct 05, 2011 3:36 pm
Quoting SASMD82 (Reply 9):
(FRA-BJS
I had to check what BJS is, never heard that before
Sure that can happen. The 340s fly higher than the 744 at the beginning of their flights. And I guess they had a lot better wind up there and maybe the 340 was in a hurry and flew faster and the 744 flew slower. Then that is possible without any doubt.
wilco737
ACDC8
Wed Oct 05, 2011 6:56 pm
Back in 1990, I was on a LH B742 from FRA-YYZ and we overtook a Wardair A310 Mid-Atlantic so I guess sometimes LH overtakes as well
Interestingly, the A310 we overtook was the same aircraft that we ended up taking from YYZ-YVR via YYC later that day ... now that was pretty cool
A Grumpy German Is A Sauerkraut
musapapaya
Tue Oct 11, 2011 5:11 pm
Funny enough, if you compare similar schedules of LH and other airlines (both long haul and short haul flights), you can see LH usually have their shorter scheduled times.
Take for example, LHR-FRA - LH sends their A320 series and scheduled time is 1:35, however, BA gives the same route 1:45, similar can be said for FRA-LHR too.
You can see similar situation with LHR-MUC too.
Lufthansa Group of Airlines
Users browsing this forum: Fiend and 1 guest
