747400sp
Do You Think The A380 Will Have A Great Safety Rec
Wed Nov 30, 2011 12:34 am
When I look at the safety record of the A340 and 777, I wonder, do you think the A380 will have as good of a safety record as the a/c mentioned earlier? I know this may look like a dumb question, bit I would like to see peoples opinion on this topic.
jetblueguy22
Wed Nov 30, 2011 12:36 am
I don't see why not. As technology advances I would assume that safety should only improve. Its tough to say though because it is still relatively new. Thus far though it isn't doing too bad.
Blue
Look at sweatpants guy. This is a 90 million dollar aircraft, not a Tallahassee strip club
Stitch
Wed Nov 30, 2011 12:38 am
I see no reason why it would not have an excellent general safety record. It's certified to stringent modern safety standards.
autothrust
RE: Do You Think The A380 Will Have A Great Safety
Wed Nov 30, 2011 7:47 am
Quoting jetblueguy22 (Reply 1):
And it has improved.
A380 features an amazing level of redundancy, much higher then the 777 or A340 plus new systems and technology's
like Electrical-Hydrostatic Actuators (EHAs) and Electrical Backup Hydraulic Actuators, Brake to Vacate/ (System prevents runway overrun's), etc...
QF32 probably would have had much worse outcome if the plane wouln't have been the A380.
“Faliure is not an option.”
Chamonix
Wed Nov 30, 2011 8:19 am
Probably.
The have ironed out nearly all the rough spots after 40 years in the business though I think it would be great if Airbus incorporated the followig mods:
1) Make sidesticks synchronous w/shaker.
2) Pitch trim thumb switch/trigger on the sidesticks used in Alternate.
3) Reconfigure stall warning so that it blares to no end until stall is over.
4) AOA indicator.
5) PVI (Para-Visual Indicator).
6) Mode selector so that crew can choose which Law they want.
7) Prots:Make them overrideable i.e. a break-out mode.
[Edited 2011-11-30 00:19:38]
Wed Nov 30, 2011 8:46 am
If the operators and regulators thought those would make things significantly safer they would implement them. The safety record speaks for itself as it is not I would say. You also fail to consider that the vast majority of accidents happen in aircraft with no mechanical faults at all.
Let me be devil's advocate here and then the experts can step in.
Quoting Chamonix (Reply 4):
Why? If the pilots can't tell a stall with current instrumentation I would be worried.
For that one in a very many case where alternate is active I would think the pilots can handle without.
That's not distracting...
4) AOA indicator.
There are arguments for this being standard, yes.
Why would that be necessary? The aircraft should always be in the "highest" possible law. Name one reason for going to a "lower" law manually.
Here's why not. In our example the aircraft is flying towards terrain. In normal law the pilots can pull on the stick(s) all the way back and get maximum pitch rate without stalling or damaging the aircraft. Without the protections they have to worry about both stall from exceeding AoA limits and snapping the wings off.
redrooster3
Wed Nov 30, 2011 9:15 pm
She should have a great safety record, i mean, if a UU A380 goes down, (God forbid!) that would be a top story for months. Thats 840 people in one plane, my goodness.
Marry one of us, and you'll fly for free!
redflyer
Wed Nov 30, 2011 9:39 pm
She'll have a stellar safety record, if nothing else because so few will take to the skies compared to other modern large aircraft.
My other home is in the sky inside my Piper Cherokee 180.
bueb0g
Wed Nov 30, 2011 10:26 pm
Quoting Starlionblue (Reply 5):
Things can get confusing, they're not always simple, especially when you have conflicting warnings (e.g AeroPeru 603.)
Better than having it come on and off, despite the fact you're still fully stalled, though I take the point
Boeing seems to manage fine. It's also the way Bombardier's doing it (Cseries); obviously, you'd need something to tell the pilots when they're exceeding the envelope (e.g more stick pressure, like on the 777/787) but there are scenarios - both ones I could come up with now, and totally unforeseeable ones - where it would be desirable to be able to break the safe flight envelope in order to save the aircraft.
Roger roger, what's our vector, victor?
Wed Nov 30, 2011 11:22 pm
Quoting bueb0g (Reply 8):
Fair enough, but can you think of any accident in a FBW Airbus (or Boeing for that matter) that would have been avoided if the pilots had gone outside the envelope?
Horstroad
Thu Dec 01, 2011 12:07 am
AF447
are you really worried?
I think this played a role on LH44 in 2008
bueb0g
Thu Dec 01, 2011 4:48 pm
I would possibly argue the AF A320 crash, although that's tenuous. I would also argue LH 2904; the non-overidable FBW did not allow the spoilers to extend to the ground detent, even though the a/c was on the ground. But to ask me to come up with a previous accident is to miss the point; unforeseen accidents happen. Before United 232 the thought of a complete hydraulic failure was not even considered. And yet it still happened. Just because a certain scenario hasn't happened in the past doesn't mean we should assume it's impossible to occur, or that we should not plan for such an eventuality - aviation safety needs to be more proactive, and less reactive.
[Edited 2011-12-01 08:49:42]
kanban
Thu Dec 01, 2011 4:59 pm
There is still the little problem the A380 has in attracting buildings, small planes and ramps to come bump and grind.. granted not a loss of life or injury situation, but......
David L
Fri Dec 02, 2011 11:58 am
There is an aural "STALL... STALL..." announcement instead, which would seem to me to be fairly unambiguous.
Quoting Chamonix (Reply 4):4) AOA indicator.
On all airliners in general, yes. I'm not sure why it would only apply to Airbus.
The whole point of the envelope protection is to make it possible to fly right at the edge of the envelope safely and consistently if required.
Quoting bueb0g (Reply 11):
If you're referring to the Habsheim/Mulhouse accident then I don't know how stalling would have helped. The systems gave the crew all the energy that was available within the laws of physics and allowed them to descend in a controlled manner, wings level, into the trees instead of "dropping". They were too low and too slow to climb over the trees with the energy they had left themselves. When it comes to physics, there is no Alternate Law.
In the history of commercial aviation, how often has an airliner been saved by stalling or by banking more than 67o, etc. We could keep on adding "what if..." scenarios till the cows come home and then we'd end up with an airliner that never leaves the gate. I'd need confirmation from Pihero, Zeke, PGNCS, etc, but I'm pretty sure that the FBW Airbus airliners have been demonstrated to be at least as capable as any other when it comes to safety manoeuvers, e.g. terrain avoidance, go-around. emergency climb/descent, roll rate, etc.
travelavnut
Fri Dec 02, 2011 12:13 pm
Quoting David L (Reply 13):
I would dare to say they are more capable of safely performing extreme manoevers.
http://www.youtube.com/watch?v=GfHTc69AFUo
http://www.youtube.com/watch?v=u-e6r66oS04
http://www.youtube.com/watch?v=eE0_dLRklTA
This is all in Normal Law, they are actually using the prots to fly right on the edge. Nuff said in my opinion. I know in which brand of airplane I want to be when they have to make an avoidance maneuver, an Airbus!
Live From Amsterdam!
Fri Dec 02, 2011 1:31 pm
Very tenuous. Being able to go outside the envelope would have just allowed them to stall and crash with a much worse outcome.
my235
Thu Dec 08, 2011 7:19 am
Quoting travelavnut (Reply 14):
And the plane is completely empty...Not going to happen at MTOW.
travelavnut
Thu Dec 08, 2011 8:34 am
Quoting my235 (Reply 16):
Which wasn't the point. The piont was that in an Airbus you can concentrate on getting out the situation and not worrying about structural or aerodynamic limits.
imiakhtar
Thu Dec 08, 2011 8:39 am
Quoting 747400sp (Thread starter):
No. I don't think it will. It's only a matter of time before the rudder jams at full deflection, an engine detaches from the pylon or it suffers an explosive decompression due to cargo door failure. After all, only the Americans know how to build aeroplanes right?
Whatever happened to Leon Trotsky?
flyingturtle
Thu Dec 08, 2011 9:59 am
Quoting imiakhtar (Reply 18):
Boeing 737, Flight 191 with a DC-10, Flight 981 with a DC-10.
Can it be said that there were paradigm shifts in designing airplanes? (I know that such ones happened in maintenance after the 191 crash: They stopped to use an easy way how to dismount an engine - the forklift solution - and did it by the book from then on...).
Myself don't believe such a paradigm shift was due to Airbus appearing on the market. Any argument in favor or against it?
David L
Thu Dec 08, 2011 10:19 am
I chickened out of going that far so thanks for taking the flak.
Quoting flyingturtle (Reply 19):
You're probably right but the appearance of Airbus did ensure the continuing presence of at least two major competing manufacturers, which has to be a good thing in that regard.
flyingturtle
Thu Dec 08, 2011 11:02 am
Just to pose that question: Is there a downloadable accident database? My statistics software isn't occupied right now...
Quoting David L (Reply 20):
Yes, they drive each other to make more efficient airplanes, at least. But manufacturers (and airlines) don't compete on safety, at least not publicly - because there are way too few accidents to make that gruesome PR from.
Is there any competition on reducing pilot workload, which also results in safer aviation? Eliminating the F/E was done because of reduced labor costs, or because they did it anyway, given the better electronics?
Referring to the A380: Does the large wing, which was planned for the A389, make this airplane safer - at least during approach?
I ask that question because a lower speed makes an accident more survivable to the people inside.
Wing loadings at MLW:
A388: 463 kgs/m^2
B744F: 527 kgs/m^2
MD-11: 590 kgs/m^2
Well, there's this song...
How many holes in the wing can a A388 have...
David L
Thu Dec 08, 2011 12:23 pm
Quoting flyingturtle (Reply 21):
I'm not sure I can agree with that. It's not that they actively market the safety, it's that it's very risky to ignore it. A single aircraft accident can generate a whole load of bad publicity for the airline and/or the manufacturer. If one manufacturer is perceived as being responsible for more bad publicity than another then a reputable airline is going to think twice before their next order.
travelavnut
Thu Dec 08, 2011 12:51 pm
Haha, much obliged   But let me add that I by no means think Boeing or other OEMs products are less safer. You just have to look at the statistics (page 22 in the link below) to see both manufacturers make extremely safe products and that their different philosophies (for example regarding flt. control) don't result in any significant difference in safety;
http://www.boeing.com/aboutus/govt_o..._accidents_statistical_summary.pdf
The Airbus way has my preference because I'm a computer and sci-fi nerd
Ask the pilots of QF032   They had quite a few holes in the wing.
tdscanuck
Thu Dec 08, 2011 2:08 pm
You're going to pull that trick and just leave Comet out of the mix?
There's some difference of philosophy...it's not exactly competition. Most OEM's are actually on the backside of this problem now, where workload is so low at many points of flight there's some legitimate risk of the pilots slacking off their monitoring functions.
All other things being equal, yes. It makes for a lower energy approach.
Tom.
autothrust
Fri Dec 09, 2011 7:52 am
Quoting tdscanuck (Reply 24):
And the A380 is capable to land at 130kts and takeoff with a speed of 145kt. Lower landing speed is always safer then high landing speeds.
http://www.aviationweek.com/aw/gener...100206p1.xml&headline=null&next=20
packsonflight
Fri Dec 09, 2011 4:35 pm
I am a bit worried about Air France since they operate the type. they where the first to crash the A320, A330 and the A340
flyingturtle
Fri Dec 09, 2011 5:35 pm
Quoting packsonflight (Reply 26):
The venerable Airbus company was the first to crash the Airbus 330.
And concerning AF340, Air France had the first crash, followed by Etihad, where the poor plane had an affair with a wall. But there were two hull losses before these accidents.
(Corrected my previous statement, the AF340 crash in Toronto was in 2005, the Etihad flight was in 2007.)
[Edited 2011-12-09 09:45:48]
chuchoteur
Fri Dec 09, 2011 7:18 pm
Quoting flyingturtle (Reply 27):
... one of those was due to "hostile action" if I remember correctly... so maybe it doesn't count lol!
cmf
Fri Dec 09, 2011 7:52 pm
Quoting Autothrust (Reply 25):
What you gain on one side is taken away on the other. The low speed increases vortexes. Also, as higher weight versions are coming online speed will increase.
Don’t repeat earlier generations mistakes. Learn history for a better future.
DocLightning
Fri Dec 09, 2011 9:11 pm
That was an Etihad frame, but wasn't it Airbus personnel? Do I recall incorrectly?
-Doc Lightning-
-Carl Sagan
Viscount724
Fri Dec 09, 2011 10:43 pm
Quoting DocLightning (Reply 30):
Believe it was a mix of Airbus and Etihad people on board. However the aircraft was still Airbus property as it hadn't yet been delivered. It appears in accident records as owned by Airbus, not Etihad.
BoeEngr
Sat Dec 10, 2011 12:02 am
I think it'll have a great safety record. Engineering practices, lessons learned and applied, regulations, redundancy, and testing all help to ensure such is the case. No reason to believe otherwise. It's about how airplanes are designed and built these days, not about which company builds them or what size they are.
flyingturtle
Sat Dec 10, 2011 8:53 am
Quoting chuchoteur (Reply 28):
Hehe. Always check your data.   Especially with accident data we should be careful which category an incident belongs to. I didn't give a good example, and most media outlets won't too.
Wasn't there a hull loss due to leakage of corrosive cargo? But don't remember the type anymore...
Buyantukhaa
Sat Dec 10, 2011 1:34 pm
The fact that it is the biggest plane may have a safety advantage in the sense that it'll be flown by the most senior (experienced) pilots of airlines... just a thought.
I scratch my head, therefore I am.
Sat Dec 10, 2011 2:26 pm
Quoting BuyantUkhaa (Reply 34):
Not necessarily true. Take an airline like CX. There are three groups of pilots. 777, 747 and 330/340. The 747 is the largest but that pilot group is not chosen by seniority. Same if CX had the 380.
Many airlines will have bidding based on seniority. If the 380 has the best routes, the most senior pilots will bid and get them. But if another aircraft type has better routes most senior pilots would bid on that. At SK, for example, many senior pilots choose the MD-80 over the 330/340 because they can sleep at home most nights.
Viscount724
Sat Dec 10, 2011 11:17 pm
Quoting flyingturtle (Reply 33):
Yes, the MH A330-300 below in 2000.
http://aviation-safety.net/database/record.php?id=20000315-0
flyingturtle
Sun Dec 11, 2011 11:22 am
Thank you!
chuchoteur
Sun Dec 11, 2011 10:23 pm
I guess the tamil tigers didn't consider that hull loss an "accident"
acedriver
Wed Jan 25, 2012 10:24 am
I think the A380 will have a safety history similar to that of the 747 - probably a few accidents involving technical issues at first, and after that it's mainly human error...
P.S AF seemed to have written off every single Airbus model apart from the A310 and the A380...
A300: F-GBEC lost in hijacking in 1994
A310: safely retired in 2002
A320: F-GFKC lost Mulhouse
A330: F-GZCP lost in the Atlantic
A340: F-GLZQ lost at YYZ
A380: safe for now
notaxonrotax
Wed Jan 25, 2012 12:25 pm
Strangely enough it´s often very senior pilots that tend to make a pig´s breakfast of the whole thing.
KLM at Tenerife must be the most famous example, but there are a lot more crashes due to a very senior pilot dropping the ball!
Examples include:
Eastern Airlines Flight 401
Flash Airlines Flight 604
Northwest Airlines Flight 255
Air France 296 (however you want to play it; this Captain is at least partially to blame)
Turkish Airlines Flight 1951
KE801: I believe captain Tong-chul was considered pretty senior too.
The A380 will be very safe; Nancy Bird Walton proves this.....the redundancy saved the aircraft.
The wing crack issues only add to this--> this is one thoroughly checked aircraft which will only improve from here!
No Tax On Rotax
For anybody that happens to be wondering:"yes, owning your own aircraft is a 100% worth it!"
acedriver
Wed Jan 25, 2012 1:46 pm
Quoting notaxonrotax (Reply 40):
I believe Crossair 3597 can be put in this catagory as well
Thrust
Wed Jan 25, 2012 7:06 pm
Definitely yes it will have a great safety record. It seems like aircraft models whose introduction is the early 1980s or more recent have racked up extremely impressive safety records...most of the accidents involving these aircraft types have been pilot error..if any have been related to the aircraft itself, those accidents have occured rarely. In particular, aircraft like the 747-400, 777, A330, A340, A319, A320, and 737NG are quite robust. Speaking with accidents themselves, in the U.S., there hasn't been a major commercial aircraft incident since November 2001 when the AA A300 went down in New York. Ten years is almost unheard of for us to go out without an accident...in prior decades, accidents happened more frequently. And even more impressive is the skills of pilots...the BA 777 and the U.S. Airways A320 that crash-landed, in addition to an AA 737 I think in the Caribbean, had everyone on board surviving. Air-to-air collisions have become almost a a thing of the past with technology. As technology improves, so does aircraft safety. So basically, with many aircraft before the A380 being fairly safe, I'm confident the A380 will be.
Fly one thing; Fly it well
Users browsing this forum: kgaiflyer and 1 guest
