LHLX
Best C-Class Seats To Europe To GRU?
Thu Mar 01, 2012 12:26 pm
I don't mind thew angled seats LH/JJ?AF/TP use....I sleep allright in them. Also, while LX does have lie flat seats, they are not v comfy to relax in.
With regards to food/service...what is the best C-class between Europe and Brazil?
Also...if LH....what is preferable? The A340 via MUC or the B744 via FRA?
neo777
RE: Best C-Class Seats To Europe To GRU?
Thu Mar 01, 2012 1:16 pm
If you plan to Fly with LH I would recommended you to go via Munich not much about the quality of the C class as they are the same%u2026. (I fly on a monthly base that route: Frankfurt is a B747-400 and Munich use A340-300 or A340-600 depending on the demand (now it%u2019s A340-600))
It is more regarding the airport. Munich is smaller them Frankfurt and the connection are way easier and faster%u2026
I have also try LX and I thought the C class of LH was better%u2026
rwsea
Thu Mar 01, 2012 6:01 pm
Of the Euro carriers, if you want flat beds you'll want to look at either BA or LX. I really liked the BA product personally. LH, AF, KL, etc. are all about the same. Decent service and consistent product but the seats are dated compared to others.
lhr380
Thu Mar 01, 2012 10:28 pm
Quoting LHLX (Thread starter):
Try BA. Lounge in FRA, great lounges in T5 to wait for your flight. Fully lie flat beds, 6ft. AVOD
LHLX
Fri Mar 02, 2012 7:59 am
I will be going Lufthansa or TAM in the end...
@NEO777: How bad is immigration in Terminal 2 in GRU where two LH flights and one JJ flight arrive within 10 minutes of each other? Also....if I take the flight via MUC it'll be a 340-300....with 2 c-class cabins....a small one behind first and a large one after doors 2L/R. Any recommendations? I guess the 1st cabin is more private and quieter...but is it more cramped?
123
Fri Mar 02, 2012 6:50 pm
lh via much much more comfortable, as described earlier, muc is nicer than fra.
Checo77
Sat Mar 03, 2012 2:09 am
Avoid FRA at all cost if you can. It was the first airport I ever got lost and neither the staff knew where to go.
I have tried LH and JJ but in Y and JJ was far better. Not sure about C though.
Adam
Czech Boeing lover living in Lima
neo777
Sat Mar 03, 2012 12:15 pm
Quoting lhlx (Reply 4):
LhLX, for the immigration if you take the Munich flight is fine.... around 10 to 15 minutes... Now with the LH flight from Frankfurt it is another story... sometime you can wait for at least 1hour....
For the JJ flight I think they arrive at the same time them Munich flight so it's ok too.
For the seat in the plane I would advise you to use the large one....
