threeifbyair
DL617 SFO-NRT Diverting To SEA
Wed Mar 28, 2012 11:04 pm
DL617 SFO-NRT, operated by a 763, is diverting to SEA according to FlightAware. Map shows it doing a circle off the Washington coast at the moment.
Medical, mechanical, or something else?
as739x
RE: DL617 SFO-NRT Diverting To SEA
Wed Mar 28, 2012 11:33 pm
I also believe this is one of the SkyTeam livery a/c. I am guessing a mechanical issue.
atcsundevil
Crew
Wed Mar 28, 2012 11:37 pm
Quoting as739x (Reply 1):
After the drama that has happened on aircraft in the past couple weeks, I think I'm out of guesses!
Forum Moderator
tp1040
Wed Mar 28, 2012 11:42 pm
Seems like quick descent from FL to 10. Not rapid but it did not take long.
threeifbyair
Wed Mar 28, 2012 11:43 pm
Based on that information, it would appear that N175DZ is the aircraft in question. According to FlightAware, N175DZ flew ATL-SFO earlier today before this flight.
It is currently working on another loop off of Forks and has already airborne for 3hrs. Presumably it needs to get under MLW, but how long will that take?
threeifbyair
Wed Mar 28, 2012 11:50 pm
Coincidentally, another DL 763 is operating LSF (Fort Benning, GA) - SEA and arriving shortly. If, by a stroke of good fortune, it is a returning military charter for Joint Base Lewis-McChord, DL would have a spare aircraft in exactly the right place.
gunsontheroof
Wed Mar 28, 2012 11:59 pm
Interesting...I'll keep an eye on the track and see if I can catch her inbound to SEA. She'll probably fly right over my house!
Quoting threeifbyair (Reply 5):
Could be, but a lot of the JBLM charters fly directly to TCM, not SEA. I was once extremely confused by an NW 742 crossing over BFI and subsequently making a south turn way too late to be going to SEA...only later did I find that it was heading for TCM. The LSF-SEA flight may well be a charter that's being repositioned to pick up these SFO-NRT folks.
Picked a hell of a week to quit sniffing glue.
twal1011727
Thu Mar 29, 2012 12:05 am
No horror stories people...
The captains window has a loud squeal eminating from it.
KD
Western727
Thu Mar 29, 2012 12:07 am
Quoting Gunsontheroof (Reply 6):
Do let us know if you observe it landing.
EDIT: content.
[Edited 2012-03-28 17:10:09]
Jack @ AUS
PHX787
Thu Mar 29, 2012 12:33 am
it says on Flightaware that it's landing shortly, as of posting....anybody at SEA have any idea what's up?
Quoting tp1040 (Reply 3):
what does that typically indicate?
gunsontheroof
Thu Mar 29, 2012 12:51 am
Quoting western727 (Reply 8):
Somehow, I missed it. Weather's pretty cloudy but the ceilings are low enough that I can still see most everything in the pattern from my front porch...probably underestimated the time delay on FlightAware and stepped outside a moment too late. Looks like it's down safely though, sure we'll hear more soon.
tp1040
Thu Mar 29, 2012 1:06 am
Quoting PHX787 (Reply 9):
Given the decent and the squeal (see above) from the cockpit window, I would "guess" pressurization problems would be a concern. To me, the squeal indicates there was an issue with window sealing system and the pilots diverted just to be safe.
Western727
Thu Mar 29, 2012 1:27 am
Quoting tp1040 (Reply 11):
I too wonder if that's the case. The fact that the 763 descended somewhat quickly and stayed at 10k while presumably getting under MLW off of WA supports your theory.
Jack @ AUS
aviationbuff08
Thu Mar 29, 2012 1:46 am
I don't believe that is coincidence. Appears that there was some type of communication between the flight crew of DL 617 and the Dispatcher back at the DL control center in ATL. Perhaps the flight dispatcher recommended the diversion to SEA because he was made aware by others that a spare aircraft was available there as opposed to air returning to SFO with no spare ETOPS aircraft. The time they spent going in circles burning off fuel to get below MLW could have been spent flying directly back to SFO.
It doesn't appear that this charter involved JBLM. The aircraft departed SEA @ 0230PST 3/28 en-route VCV-LSF-SEA. The charter appears to have been for the VCV-LSF and they (DL) just used a 767 that would have RON/RAD in SEA 3/28. You are correct that charters for JBLM do in fact use TCM as opposed to SEA as I have seen flight plans filed for TCM.
ssteve
Thu Mar 29, 2012 1:53 am
Might be a Mariners Japan charter in this mix somewhere.
roseflyer
Fri Mar 30, 2012 3:38 am
Quoting aviationbuff08 (Reply 13):
That could be, but a fully equipped maintenance base can get a window changed in about an hour. SEA is a major DL maintenance base, so I'd expect them to have the equipment to swap out a window and the airplane was only on the ground for about 2 hours.
dumbell2424
Fri Mar 30, 2012 5:38 am
gocaps16
Fri Mar 30, 2012 2:19 pm
Quoting SSTeve (Reply 14):
Can't be. The Mariners arrived into NRT last week. It was all over on the Japan News regarding Ichiro Suzuki playing in his turf. Prior to opening day, the Seattle Mariners played against the Yomiuri Giants.
BoeingGuy
Fri Mar 30, 2012 8:29 pm
I thought the 767-300ER has fuel jettison. Why would they be circling for three hours to get down to MLW?
