bobnwa
Connecting Delta Main Terminal To MAT LGA
Sat Mar 31, 2012 5:40 pm
Is there ground transportation between Delta main terminal to shuttle at MAT at LGA and how often does it run?
deltairlines
RE: Connecting Delta Main Terminal To MAT LGA
Sat Mar 31, 2012 6:08 pm
There's a landside bus that runs every 15 minutes or so - it's about a 10-15 minute ride (probably closer to 15 given that it stops at the CTB as well on the way to the MAT).
You do have to reclear TSA though - nothing airside.
KingFriday013
Sat Mar 31, 2012 7:09 pm
How'd you pull that off? I've NEVER seen an itinerary that lets you connect mainline/Connection to Delta Shuttle... unless you made two separate reservations
But yes, there's a Delta-branded landside bus that hits A (MAT), C and D (this one doesn't stop at the CTB, only terminals served by DL). Like DeltAirlines said you'll have to reclear security, although at the MAT that probably won't take more than 5 or 10 minutes.
http://www.delta.com/traveling_check...ation/airport_maps/newyork_lga.jsp
-J.
Tho' I've belted you an' flayed you, By the livin' Gawd that made you, You're a better man than I am, Gunga Din!
deltairlines
Sat Mar 31, 2012 7:20 pm
Quoting KingFriday013 (Reply 2):
I've pulled it off in the past doing it as a multi-city connection to force it through the system, but without doing it manually like that, the system won't show it.
bobnwa
Sat Mar 31, 2012 7:24 pm
Quoting DeltAirlines (Reply 1):
Thanks for the help, am I right in thinking that you cannot check a bag ie: CLT-LGA-BOS
deltairlines
Sat Mar 31, 2012 8:31 pm
Quoting bobnwa (Reply 4):
I don't believe so, though I've never had to deal with checked luggage when doing these connections.
Users browsing this forum: JJ777 and 1 guest
