Captaindoony
Connecting Question
Wed May 16, 2012 11:10 pm
Im flying from FRA-LGW in June with LH and then LGW-ABZ with Flybe.
Now of course this is two separate bookings but the BE flight departs from the same terminal as the LH flight arrives at so can I go through connections or do I need to head out the exit and back through security?
Your help is appreciated
HT
RE: Connecting Question
Fri May 18, 2012 6:59 am
The U.K. is not part of the Schengen area.
You therefore need to clear Immigration down south of the border (= at LGW).
If you have your BP for yor BE-flight at hand (after OLCI) you can use "Flight connections" if this exits and you do not have luggage checked.
-HT
Users browsing this forum: ucdtim17 and 1 guest
