747400sp
Airlines Likely To Use A330NEO,A320NEO & 737M?
Fri Jul 06, 2012 5:30 pm
Let's say, that Airbus goes ahead with the A330NEO, which airlines, are likely to operate A330NEOs, A320NEOs and 737MAXs?
The days, of airlines having an all Airbus or Boeing fleet, was a thing of the 90's, and is almost over, and I somewhat would like to see this fleet mixer. So could you see such a fleet, and if so, which airlines will have it?
Stitch
Fri Jul 06, 2012 6:02 pm
Delta comes to mind. But that is about it at the moment.
1337Delta764
RE: Airlines Likely To Use A330NEO,A320NEO & 737M?
Fri Jul 06, 2012 6:11 pm
Quoting Stitch (Reply 1):
I'd disagree; Delta will most likely order the 737 MAX, and does not presently have a need for additional widebody lift. DL is spending millions upgrading the interiors of the 767 fleet, so it will be a long time until DL starts replacing them. By the time DL decides to replace the 767s, they will probably already be accepting delivery of the 787s, so the A330NEO wouldn't make much sense by that time.
The Pink Delta 767-400ER - The most beautiful aircraft in the sky
roseflyer
Fri Jul 06, 2012 7:02 pm
It is really hard to come up with any airline that would operate such a fleet, especially because Airbus has publicly said that they are not going to re-engine the A330. It’s an airplane that will never exist, so who could we expect to operate it?
There no doubt will be some airlines with split 737MAX and A320NEO fleets. American and NAS are two. There will be more. I expect the Chinese airlines will end up ordering both and maintaining a mixed fleet. Other politically influenceable airlines in countries that try to remain neutral like Turkish likely will split as well.
I am under the impression that the A330NEO concept was invented by journalists and aviation enthusiasts. Airbus has stated that they are willing to invest in the A330 to increase MTOW and add sharklets, etc. If the question is who will order such an airplane along with the MAX and NEO, then I have to assume it would be from China. AA and Norweigian have ordered 787s and don’t operate A330s. I think any enhanced A330 would be ordered by an existing A330 operator.
