Pe@rson
70-minute Connection In CPH (SK To SK)
Tue Jul 31, 2012 6:37 pm
Hi Folks,
I will be purchasing a one-way ticket from FRA to LON (LHR or LCY). One option, not much above the best-timed flight for me, is SK to LHR via CPH. (This would also permit a new aircraft type, new airport, and new airline.) But I'd only have 1h 10m to connect in CPH. Is this sufficient?! I may not choose this, but I am curious about the viability of it.
James.
cmf
RE: 70-minute Connection In CPH (SK To SK)
Tue Jul 31, 2012 7:36 pm
You should be fine. Min connection time is 40 minutes for Schengen to non-Schengen.
Don’t repeat earlier generations mistakes. Learn history for a better future.
Tue Jul 31, 2012 8:00 pm
Very easy I have had a 65 mins connection ATH-CPH-DUB and still got 15-20 mins in the lounge . CPH is very easy to connect at.
aloges
Tue Jul 31, 2012 8:55 pm
As the others have said, it's going to be easy unless you're severely delayed. I haven't cleared passport control at CPH, but I cannot imagine that it might take you very long.
That said, CPH is a very nice, if expensive, place to be and you get free and fast WiFi after registration. If you stil have the chance, I hope I may suggest that you take it.
757MDE
Tue Jul 31, 2012 11:37 pm
I connected MUC CPH AMS in literally 20 minutes after landing.
Quisiera volveraamartevolveraquerertevolveratenertecerrrrcaademígirl! Mis ojos lloran porrr ti...
Wed Aug 01, 2012 4:32 am
70 minutes is more time than enough for your connection at CPH.
Try to get on an MD80 before SAS gets rid of them all.
Pe@rson
Thu Aug 02, 2012 1:08 pm
Thanks folks. I booked FRA-CPH-LHR and I'll fly the M81 (rare nowadays and my first of the type) and 319.
Hywel
Thu Aug 02, 2012 2:17 pm
Quoting Pe@rson (Reply 6):
All of SAS's MD81s have been converted into MD82s. Although I'd still log one of the converted aircraft as an MD81 as that's the way it was first built
To make it confusing, SAS also have MD82s (manufactured as MD82s) that are referred to as MD81s on the timetable.
You'll either get an original MD82 or a converted MD82 anyway  Smile
More info including conversion dates for the old MD81s: Link
[Edited 2012-08-02 07:23:32]
Pe@rson
Thu Aug 02, 2012 6:14 pm
Quoting Hywel (Reply 7):
How frustrating! I wasn't aware of it. I'm pleased you pointed it out.
Seems somewhat cheating, but...
[Edited 2012-08-02 11:18:34]
TUGMASTER
Thu Aug 02, 2012 6:47 pm
More than enough time...
Have done LHR-CPH-LPI transit connection in 10 mins.....
mind you , some leg work involved in that one,
+ when i arrived, the LPI gate was stilll closed 15 mins prior to dep.
Hywel
Thu Aug 02, 2012 9:02 pm
Quoting Pe@rson (Reply 8):
The main difference is the upgraded engines with increased thrust. If you took a Boeing 747-200 and put higher thrust 747-400 engines on it, it'd still be a -200 series right?
aloges
Thu Aug 02, 2012 10:00 pm
Quoting Hywel (Reply 10):
I think it might be getting dangerously close to a VC-25!
Pe@rson
Fri Aug 03, 2012 7:49 am
Thanks folks.
CrimsonNL
Fri Aug 03, 2012 2:56 pm
While it was a transfer within the Schengen area, my AMS-CPH-ARN transfer took me exactly 2 minutes! All within the B concourse.
Martijn
Users browsing this forum: B6JFKH81 and 9 guests
