mplsjefe
NRT Security Screen Between Flights Question
Sun Aug 05, 2012 2:40 pm
Greetings fellow Anetters!
We will be flying MSP-NRT-SIN early next year (in BusniessElite on a 77L for the first time, very excited!) and I am wondering if we will have to get off the plane and go through the, at times, very slow and inefficient between flight segment security screening in NRT. The MSP-NRT-SIN segments are on the same 77L but we have different seats and different ticket numbers/reservations (used miles for the long segment, paid for the short segment).
The HKG-MSP flight via NRT is on different 77Ls so I assume we will have to go through the "middle man" on the way back.
Any insights/ideas/comments would be appreciated.
Also, I have my fingers crossed that the 77L will go back to a 74S with the new Business Elite mod, but I won't hold my breath.
MSPjefe
LAXintl
RE: NRT Security Screen Between Flights Question
Sun Aug 05, 2012 9:25 pm
Yes you will clear security at Narita.
You will deplane and have option of either being channeled to Japan arrivals or the transfer section. Since you are continuing you will go towards transfer and reclear security.
roseflyer
Mon Aug 06, 2012 4:08 am
Yes you clear NRT security. I am not sure how you got such a negative opinion for it. It has never taken me more than ten minutes.
Coal
Mon Aug 06, 2012 1:58 pm
Quoting Roseflyer (Reply 2):
I would say 10mins at most from the first few rows of Y on an SQ A380 to the NH lounge. It is VERY efficient.
Coal
Nxt Flts: SQ SIN-CGK-SIN | SQ SIN-BKK-SIN | KL SIN-DPS-SIN
LAXintl
Mon Aug 06, 2012 2:29 pm
IMO, NRT can be hit or miss for the security time.
I've arrived and been the first one in line at times, while others there have been hundreds of people in front with the queue backed up down the gate concourse.
I think its really a matter of how many other simultaneous arrivals there are those few minutes and how many hundred/thousand passengers are dumped in the concourse at the same time.
steex
Mon Aug 06, 2012 3:30 pm
Quoting mplsjefe (Thread starter):
Keep in mind that flight number doesn't directly correspond to aircraft. Though DL 621 is a single flight number MSP-NRT-SIN and both segments are operated by the 77L, there is a non-zero chance that they will be operated by different aircraft.
PHX787
Mon Aug 06, 2012 4:10 pm
Quoting LAXintl (Reply 1):
There's two distinct lines and recently the staff has been checking everyone to make sure they're going to the right place
Quoting LAXintl (Reply 4):
Arrivals for me has been about 20 minutes from deplaning to getting a ticket for the bus. I absolutely love how quick NRT is. Always very welcoming too, and actually does nothing to help the overwhelming fact that I've returned to Japan (which is quite overwhelming for me, given my area of study)
mplsjefe
Tue Aug 07, 2012 12:37 am
The 6 times I have been through NRT only once did it take less than 30 minutes to get through security, and once in May of this year it took 1.5 hours. It did seem like earlier in the day things went more smoothly.
[Edited 2012-08-06 17:46:15]
PHX787
Wed Aug 08, 2012 9:12 am
Quoting mplsjefe (Reply 7):
I'm curious to know which airline and terminal you're flying through. Always for me, DL, and terminal 1, there are no issues.
steex
Wed Aug 08, 2012 4:25 pm
Quoting PHX787 (Reply 8):
I'm rather surprised by this also. I've generally had it take between 2 and 20 minutes, with 30 minutes being the absolute max.
To the OP, keep in mind that when flying in BE you will at least get to security before almost everyone else on your plane. That can be a huge benefit at times.
mplsjefe
Thu Aug 09, 2012 12:12 am
Me too, never in BE but always in Y+ so not a huge difference. Maybe I'm just unlucky or have been in NRT on days when they are understaffed...
copter808
Thu Aug 09, 2012 3:16 am
I have been through there many times and it's relatively painless. Since you are BE, you go through a seperate line and it should not take long at all. Unless your first flight is late, you'll still have time for the lounge.
sw733
Thu Aug 09, 2012 6:24 pm
I agree. There was a time a couple years ago when I transited NRT about 8 times a year, and sometimes it would take 5 minutes, and another 30. Even coming off of the same flight number at the same time.
[Edited 2012-08-09 11:24:56]
mplsjefe
Fri Aug 10, 2012 12:01 am
Quoting copter808 (Reply 11):
Is the BE line separate from the Sky Priority line? If it is then that makes sense.
I have never gone BE but I am a platinum medallion and always use the sky priority line. Last time we went through, they were so overwhelmed they were just splitting everyone up between the two lines and even had people go downstairs to that line as well . . .
PHX787
Sat Aug 11, 2012 12:12 am
Quoting mplsjefe (Reply 13):
What does BE stand for?
Quoting mplsjefe (Reply 10):
I did hear from a friend that says Narita has a certain time which Terminal 2's international arrivals area is overcrowded because of rush hour.
mplsjefe
Sat Aug 11, 2012 3:09 pm
Quoting PHX787 (Reply 14):
BusinessElite.
PHX787
Sat Aug 11, 2012 5:37 pm
Quoting mplsjefe (Reply 15):
BusinessElite.
I don't recall any separate lines, all I know is that they obviously deplane first and get to the front of the line first.
Except for last year, when I was on DL275 (744) I was towards the front in Y+ and for some reason I was the very first off the plane and through customs without any issues. Most of the time spent was walking all the way to the customs line from our gate.
copter808
Sun Aug 19, 2012 5:16 am
Quoting PHX787 (Reply 16):
I have flown into NRT several times, usually on CO/UA anf TG. In clearing security for a connecting international flight, there are two lines. One for First/Business class, and another for the rest of us. The First/Business will not remain empty though and will be used for we peons when necessary.
WROORD
Sun Aug 19, 2012 6:52 pm
This past June I flew UA ORD-NRT-TPE and security took less than 5 minuted. Mind you UA had 747 from ORD and based on how many people took japanese customs forms I would say that half transfer to other flights.
The flight arrived after 3 PM and everything was very efficient as well as everyone at NRT spoke excellent English.
Our flight to TPE arrived late from SFO, but they still managed to have us leave on time.
I wish all United staff in US was as courteous and efficient as their Japanese employees.
xjramper
Mon Aug 20, 2012 3:09 am
Of the two dozen or so times I have flown through NRT, whether it was intra-asia into NRT or US into NRT, I can only recall there being more than a 30 min wait once and our DTW-NRT flight was super late which put us as the last 744 into NRT with the majority of the US-NRT bank having already arrived and going through customs. Both security areas were filled to the brim and it was probably no more than 35 mins to get probably 800 or so people through both checkpoints.
More times than I can remember, there was only three or four people in front of me at security.
Look ma' no hands!
Users browsing this forum: No registered users and 16 guests
