Birdwatching
United Aircraft Number 3435 (739)?
Sun Aug 12, 2012 9:42 pm
I just flew EWR-IAH on United on a 737-900, presumably ex Continental. I normally write down my tail numbers but didn't bother as United's web site lists the aircraft numbers on their web site. So now it says "Aircraft number 3435" and I can't seem to find any info about which actual N number goes with it.
Any help would be appreciated!
Soren
All the things you probably hate about travelling are warm reminders that I'm home
airtrainer
RE: United Aircraft Number 3435 (739)?
Mon Aug 13, 2012 1:23 am
Hi Soren, you were on N75435 according to libhomeradar.org
Life is short : eat dessert first !
AirframeAS
Mon Aug 13, 2012 3:29 am
UA usually lists the nose number rather than the N number. I have no idea as to why they do this.
Birdwatching
Tue Aug 14, 2012 5:27 pm
Isn't this extremely confusing? Why use 2 different numbers for your fleet with no way to tell one if you know the other?
Soren
fshplns
Wed Aug 15, 2012 1:11 am
Quoting airtrainer (Reply 1):
Just checked it in our system. A/C 3435 is exactly as airtrainer states, N75435, a 737-900. With the merger going on, in the end, all UA aircraft will have 4 digit a/c #s. The 3000 a/c numbers are from the CO side, and the 4000s from the UA side, and those are the mainline flights only. COs was originally a 3 digit number.
Chris
AirframeAS
Fri Aug 17, 2012 12:34 am
Quoting fshplns (Reply 4):
I thought the sUA aircraft N numbers were going to stay the same, but all new incoming aircraft will have the NXXXXX "full numeral" tail number from this point on regardless if the aircraft was a sUA order or a sCO order....
Birdwatching
Mon Aug 20, 2012 2:59 am
Thanks for all your replies!
Could you also please get me the tail number of sister ship # 3451?
Is there any on line source to convert a UA aircraft number to their respective N number?
Thanks a lot!
Soren
fshplns
Mon Aug 20, 2012 4:03 am
Quoting Birdwatching (Reply 6):
Soren,
N38451 737-900
Quoting AirframeAS (Reply 5):
Absolutely correct. All previous aircraft should be staying the same bureau they were, only with the new builds, a/c will be N(full numeral).
Chris
Users browsing this forum: hoons90 and 1 guest
