fahadmk
Transiting In Doha- Premium Terminal
Mon Aug 20, 2012 5:08 pm
Hi Everyone!
Does anyone know if you are arriving into DOH on Qatar Airways, in Economy, but connecting onwards on a Qatar Airways Business class flight; Do you get Premium Terminal Access?
flown on..747-200/300/400 - 777-200/200ER/200LR/300/300ER/ - 767-200/300ER - 757-200/300 - 737-300/400/500/600/700/900/9
blueflyer
RE: Transiting In Doha- Premium Terminal
Mon Aug 20, 2012 11:27 pm
Quoting fahadmk (Thread starter):
Yes.
Try and make sure the crew on your inbound flight is aware that you are continuing in Business. First and Business class passengers get their own bus straight to the premium terminal. If you miss that bus, you'll be directed to the main terminal with other coach passengers. Once inside the main terminal, airline employees ought to be able to assist you with your transfer to the premium terminal.
Do keep in mind that if you find yourself in the main terminal and you just want a good lounge with food and a shower, the Oryx lounge is a perfectly acceptable option and it doesn't require a change of terminal.
Democracy 2016: 3 million California votes < 100,000 Midwest votes.
toptravel
Sun Aug 26, 2012 2:48 pm
Just make sure the check in staff for your first sector realize your connecting to B/C they will give you a voucher for the Premium terminal, you need to get on that bus at the bottom of the aircraft steps, it will take you directly to the premium Terminal. Once inside show your onward boarding pass and your all set. Have a good trip...on QR you have a pretty good chance of one.
Users browsing this forum: masgniw and 1 guest
