jkrugman22
DL295 Stops?
Sat Oct 06, 2012 7:17 pm
Hi - long time reader, first time poster. I've noticed on flightaware DL295 occasionally making a stopover. A few days back in ANC - today in SEA. I know flightaware is not the most accurate when it comes to routing, but was wondering if anyone had any insight as to why. I'm curious since I'll be on that flight a few times over the next 3 months.
Thanks.
alfa164
RE: DL295 Stops?
Sat Oct 06, 2012 8:06 pm
Flagstopped in SEA today due to fuel capacity; probably heavy headwinds. ATL-NRT is a long flight...
PHX787
RE: DL295 Stops?
Sat Oct 06, 2012 8:42 pm
Quoting alfa164 (Reply 1):
Is this on a 744? why don't they use a 77L?
alfa164
RE: DL295 Stops?
Sat Oct 06, 2012 8:51 pm
Quoting PHX787 (Reply 2):
376 seats full vs. 269 is probably the best answer...
PHX787
RE: DL295 Stops?
Sat Oct 06, 2012 8:57 pm
Quoting alfa164 (Reply 3):
Here come the ever hated 748 question    , but do you think this could make the route better without stopping?
SonomaFlyer
RE: DL295 Stops?
Sat Oct 06, 2012 10:44 pm
Stopping in SEA to take on fuel adds cost for DL. However, they are apparantly comfortable using a 744 instead of a 77L given the loads and presumably the yields.
DL seems to enjoy taking used a/c into its fleet and stretching out the life of their existing a/c. The fuel refinery will increase that benefit as their older a/c won't cost the same to fuel as say US or AA's.
A 748 on that route would be great but DL isn't springing for them.
brilondon
RE: DL295 Stops?
Sat Oct 06, 2012 11:21 pm
Quoting SonomaFlyer (Reply 5):
That's alot of money for just one route plus you need at least 2 748's on the route and DL probably doesn't want to spend that kind of cabbage on purchasing the aircraft.
Rush for ever; Yankees all the way!!
MSPNWA
RE: DL295 Stops?
Sat Oct 06, 2012 11:22 pm
I don't remember this route making many fuel stops the last time it was a 744. Winds must be really bad lately. The flight has been over 14 hours on some days, and that's the limit for their 747s.
rfields5421
RE: DL295 Stops?
Sat Oct 06, 2012 11:33 pm
Looks like the jet stream has been running 110 to 140 kts off Kamchatka recently. I've looked at some other NRT flights, and they are going far north, or south of their normal route.
lucky777
RE: DL295 Stops?
Sat Oct 06, 2012 11:42 pm
Did the MD-11 ever have to make fuel stops on the ATL-NRT runs during the winter months? I recall it having trouble on LAX-HKG but i wasn't aware of ATL-NRT having fuel issues. And yeah, the headwinds must be brutal because ATL-NRT is considerably shorter than ORD-HKG, which i know UA used to run their -400's on and still might, i'm not sure.
Perhaps the better question would be why not put a 77E on the route, while not nearly as much range as the 77L it would still have plenty of legs to make the run even with bad headwinds.
SonomaFlyer
RE: DL295 Stops?
Sat Oct 06, 2012 11:45 pm
I don't think DL would want to go down to a 77E. First, they take out a lot of revenue in the form of passengers and cargo. Second, they might also take a weight penalty westbound with the winds aloft as strong as they are right now. Fourteen hours is a LONG flight for a 77E.
B4REAL
RE: DL295 Stops?
Sat Oct 06, 2012 11:58 pm
Quoting lucky777 (Reply 9):
Also consider that all 744 are not created equal. NW removed the tail stabilizer fuel tanks I believe, slightly reducing the range for their 744 fleet. UA has them intact I believe.
pqdtw
RE: DL295 Stops?
Sun Oct 07, 2012 12:02 am
It happens very infrequently. The 744 is well-capable of ATL-NRT. The winds have been monstrous of late -- no reason though to throw the 744 off the route for the couple of times this happens every few years!
lucky777
RE: DL295 Stops?
Sun Oct 07, 2012 12:04 am
Quoting B4REAL (Reply 11):
Any idea how much of a range penalty that is good for?
jkrugman22
RE: DL295 Stops?
Sun Oct 07, 2012 12:07 am
I'm curious, what drives the decision to stop in ANC vs SEA?
United1
RE: DL295 Stops?
Sun Oct 07, 2012 12:09 am
UA still flies ORD-HKG with a 744 but keep in mind it takes a polar route so it may encounter less headwinds than ATL-NRT which takes a Pacific track.
They do IIRC....
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
rwy04lga
RE: DL295 Stops?
Sun Oct 07, 2012 3:32 am
Quoting jkrugman22 (Reply 14):
ANC is along the great circle route from ATL-NRT, SEA is much farther south. Even if they weren't stopping at ANC, they'd still fly right over it. Welcome to Airliners.net!
Just accept that some days, you're the pigeon, and other days the statue
PHX787
RE: DL295 Stops?
Sun Oct 07, 2012 3:42 am
They also have some significant presence at SEA too
