flyenthu
IAH To CCU
Sat Jan 19, 2013 6:15 pm
Hello:
I am thinking forward to July regarding a trip to Kolkata from Houston. I have done this on BA (does not fly CCU anymore), SIA, and EK. I am debating between SIA and EK right now, but I am quite open to other options as well. Which one do you suggest? Long layover durations doesn't bother me, and a route with more comfort (low turbulence) is preferred.
Thank you!
AR385
RE: IAH To CCU
Sat Jan 19, 2013 8:06 pm
Quoting flyenthu (Thread starter):
If you go with SIA wouldn´t you have to backtrack a long way?
flyenthu
RE: IAH To CCU
Sat Jan 19, 2013 8:11 pm
Yes, when I flew on it in Dec 2010, it went right over and past Kolkata, and then after a long layover in SIN, we took a brand new A330 from SIN-CCU.
AR385
RE: IAH To CCU
Sat Jan 19, 2013 8:41 pm
To be honest, unless you are flying F and have access to lounges etc. backtracking 4 hrs after flying 20 plus a layover sounds grueling.
I once had to do MEX-FRA-EZE for work, in F, and it´s not something I would like to do again.
FlyingSicilian
RE: IAH To CCU
Sun Jan 20, 2013 1:58 am
Well, Turkish is starting service to IAH this summer, though I do not know if they fly CCU from Istanbul.
Qatar serves IAH to Doha and then has non-stops to CCU.
LH goes via FRA and Mumbai so that is two stop, but so is SIA with the DME and SIN stops.
I've heard good things about Qatar up front.
“Without seeing Sicily it is impossible to understand Italy.Sicily is the key of everything.”-Goethe "Journey to Italy"
flyenthu
RE: IAH To CCU
Tue Jan 22, 2013 2:24 pm
It is SQ. Just booked a flexi fare, just in case plans change. Couldn't let go of the great prices.
