Lofty
Humanitarian Aid Project
Tue Jan 22, 2013 5:01 pm
I am working on a Humanitarian Project and need to look into the best aircraft fleet.
With all you knowledge and experience which aircraft would you use for the following missions and why:
1. Heavy transport eg equipment and supplies into man made strips.
2. Medium / Light transport from above onto unpaved strips.
Many thanks
TWA772LR
RE: Humanitarian Aid Project
Tue Jan 22, 2013 8:53 pm
There are lots of carriers that use old Soviet cargo aircraft for missions such as these, be it humanitarian or military. I'd suggest you check with one of them. They may be the cheapest and most readily available. On top of that, old Soviet cargo aircraft are built like tanks! That's all the info I know. I'm 110% sure that someone on here will know much more than I do.
Good luck on your endeavors.
And for my next miracle, I'm gonna turn water into funk!
cannibalz3
Wed Jan 23, 2013 12:10 am
Man, you need waaaay more information that that -- approximate runway length? Flight distance? How much can you spend? I'd also consider asking on a specialized pilots forum -- this place is great, but not quite what you're looking for. Try PPRune or somesuch.
tdscanuck
Wed Jan 23, 2013 2:19 am
Quoting Lofty (Thread starter):
AN-125 if you don't have good ground equipment, 747F if you do.
Something like a C-295 or C-130 is great for this.
Tom.
