raptors
FRA-LAX-FRA 748?
Wed Jan 23, 2013 4:32 pm
Hi,
I am thinking of booking a flight from LAX to FRA in about 10 days and from what I can see the 748 is supposed to be used on this run.
According to flightaware though there seems to have been some 744's operate recently, namesly D-ABVY on the LH457 on 17th AND 18th, yet these did not operate the LH457.
Is anybody out there able to confirm that the 748 is likely to be used, unless tech of course?
Many thanks.
LH456 was flown on 2013-01-23 by D-ABYC (B748)
LH456 was flown on 2013-01-22 by D-ABYA (B748)
LH456 was flown on 2013-01-21 by D-ABYC (B748)
LH456 was flown on 2013-01-20 by D-ABYF (B748)
LH456 was flown on 2013-01-19 by D-ABYA (B748)
LH456 was flown on 2013-01-18 by D-ABYD (B748)
LH456 was flown on 2013-01-16 by D-ABYF (B748)
LH456 was flown on 2013-01-15 by D-ABYA (B748)
LH456 was flown on 2013-01-14 by D-ABYD (B748)
LH456 was flown on 2013-01-13 by D-ABYA (B748)
LH456 was flown on 2013-01-12 by D-ABYC (B748)
LH456 was flown on 2013-01-11 by D-ABYA (B748)
LH456 was flown on 2013-01-10 by D-ABYC (B748)
LH457 was flown on 2013-01-23 by D-ABYA (B748)
LH457 was flown on 2013-01-22 by D-ABYC (B748)
LH457 was flown on 2013-01-21 by D-ABYF (B748)
LH457 was flown on 2013-01-19 by D-ABYA (B748)
LH457 was flown on 2013-01-19 by D-ABYD (B748)
LH457 was flown on 2013-01-18 by D-ABYD (B748)
LH457 was flown on 2013-01-18 by D-ABVY (B744)
LH457 was flown on 2013-01-17 by D-ABVY (B744)
LH457 was flown on 2013-01-16 by D-ABYF (B748)
LH457 was flown on 2013-01-15 by D-ABYA (B748)
LH457 was flown on 2013-01-14 by D-ABYD (B748)
LH457 was flown on 2013-01-13 by D-ABYA (B748)
LH457 was flown on 2013-01-12 by D-ABYC (B748)
LH457 was flown on 2013-01-11 by D-ABYA (B748)
LH457 was flown on 2013-01-10 by D-ABYC (B748)
SSC/111/146/AR8/AT7/AN3/AB4/6/310/319/20/21/332/3/343/6/703/722/732-9/74L/2/4/F/752/3/772/3/W/E170/190/CR7/9
HT
RE: FRA-LAX-FRA 748?
Wed Jan 23, 2013 5:34 pm
I think you have done the maths already on your own by looking up the history.
Furthermore, on LH's online time table it continues to be a B748 scheduled for the said flights until summer time table.
-HT
wilco737
Wed Jan 23, 2013 6:29 pm
The 748 is scheduled on the 748 and i haven't heard any change in that.
I flew that route myself last week and both flights were pretty full.
The change to the 744 was due to the weather in FRA and its delays and late arrival of the airplanes.
Happy flying.
raptors
Wed Jan 23, 2013 6:30 pm
Thanks HT, I hope it remains so, especially as it is a slightly longer way home!
Raptors......
stylo777
Thu Jan 24, 2013 6:31 pm
Quoting Wilco737 (Reply 2):
If I'm not mistaken this swap was technical related, not wx...
wilco737
Fri Jan 25, 2013 7:00 am
Quoting stylo777 (Reply 4):
Both. Due to the weather in FRA the airplane had to be de-iced and during de-icing a problem showed up due to the de-icing. So both.
wilco737
DTWLAX
Sat Jan 26, 2013 7:06 pm
Quoting raptors (Thread starter):
That data should give you the answer? If a 748 flew into LAX on 18th, how can a 744 fly back? Flightaware glitch?
Also why are there 2 LH457s on the 18th and no LH456 on 17th?
Quoting Wilco737 (Reply 5):
The data above does not add up. If a 744 did fly into LAX as a sub, it should fly back to FRA the same day from LAX. Data does not show that.
Users browsing this forum: HVNwxROC and 18 guests
