AirCanada787
Air Canada EUpgrade Question
Thu Feb 14, 2013 5:07 am
I have a Air Canada eUpgrade question for a friend.
He was going to book JNB-YYZ via FRA on Lufthansa with the first leg operated on LH and the second AC. He was wondering if he could still use an eUpgrade on FRA-YYZ even though the ticket was booked with LH or if he had to book with AC to be able to use the upgrade.
Basically the question is can you use the eUpgrades on any Air Canada flight you are on regardless of who you book with, or do you have to book the flight with Air Canada to be eligible to use them.
The mind, like a parachute, functions only when open.
BE77
RE: Air Canada EUpgrade Question
Thu Feb 14, 2013 3:21 pm
The E upgrades are only good on AC metal, and what your friend is doing should work I think (although check the details, because you never know). Overall, it does look the same as many trips I have taken where I have upgraded on the A C portions of the intinerary.
Tower, Affirmitive, gear is down and welded
AirCanada787
Fri Feb 15, 2013 7:31 pm
Quoting BE77 (Reply 1):
Thanks for the reply BE77!
Users browsing this forum: BENAir01, Raventech and 2 guests
