DFWHeavy
Confirmation Number (PNR) Question
Thu Feb 14, 2013 1:45 pm
How long is it before confirmation numbers (PNRs) are reused? Say I book today for a round trip in October 2013.. Once my flights are complete, how long will it be before that confirmation is put back in the rotation and assigned to someone else?
Christopher W Slovacek
DFWHeavy
RE: Confirmation Number (PNR) Question
Fri Feb 15, 2013 2:52 pm
Anyone have any idea?
LAXintl
Fri Feb 15, 2013 3:02 pm
Search -
How Long Before A PNR Number Is Reused (by Lincoln Sep 11 2005 in Civil Aviation)
But basically within 3-days of use it can be recycled.
DFWHeavy
Fri Feb 15, 2013 8:22 pm
Very interesting.. Thanks LAXintl. That really surprises me. I thought it would be a much longer wait before they are recycled and used again.
Based on a six digit alpha-numeric PNR combo, how many possible combinations can an airline have?
Fri Feb 15, 2013 9:08 pm
I can only speak for Amadeus.
A PNR is "deactivated" 5 or 6 days after the last segment, and can then be theoretically be reused.
However most trravel agencies would place a MIS element in the PNR, which is basically a retenrion element. It will be placed i.e. 6 months after the last segment. This will then hold the PNR valid way longer until that date. THis is useful in case guests are noshow, do complain, need to rebook etc, since once a PNR is not available in Amadeus anymore it is difficult to retrieve it (there are options, but it's quite a pain).
Freshside3
Sat Feb 16, 2013 3:40 am
Quoting reifel (Reply 4):
The "retention element" that most airlines and agency uses is a segment with a fake flight number, usually with the code "ZZ"(which doesn't exist) for the carrier, and an easy to remember number......the segment is booked a few months out......and often uses a really absurd flight routing, which the agency/airline takes creative liberties in booking.
Typical flight numbers could be ZZ1000, ZZ1234, ZZ9999, etc.........and routings could be something like BTV-LAS, PIR-BIS, or even airport codes with no commercial service(i.e. HHR-HWD). Plus the times almost always show midnight.
ZZ1234 25JUN HHRHWD 1200m 1200m is an example of this kind of segment, in the PNR.
(1) Fake carrier & flight #; (2) date a few months out; (3)City pair---could be legitimate or non-existing route; (4) Times showing departure and arrival both at midnight.
Mon Feb 18, 2013 9:10 pm
Quoting FreshSide3 (Reply 5):
Thanks very much. I believe this is however not used in Amadeus. In Amadeus a MIS element is used, Also called RU-Element in some countries... This usually doesn't contain a flight segment, but a three city code. In Checkmytrp this leads to strange entries showing as "MISCELLANIOUS FRANKFURT (GERMANY) 21JUN13" or something. The entry would be "RU 1A NN2 FRA 21JUN".
The ZZ is interesting though. Maybe this is still used in other GDS' or was used in the past in Amadeus (and still is with some agencies/tour operators). In Amadeus all I knew about ZZ is that it is a two letter code used for carriers which are not loaded in Amadeus. Some tour operators can i.e. use this to create passive bookings in Amadeus for system purposes when they contract i.e. a full charter... I.e. you would contract a flight with Titan Airways flight 7999 flying for a cruise from Bournemouth to Genoa, you could enter the flight details as flight ZZ7999 29JUN BOHGOA or something...
Users browsing this forum: sasquatchh and 19 guests
