novak500
Connection Through Keflavik
Wed Feb 27, 2013 5:56 am
Just booked my summer vacation (super excited) and it's a combination of Paris and Iceland with all flights on Icelandair as i wanted to take advantage of the free stopover in Iceland for a few days on the return leg. The first segment is YYZ-KEF-CDG with a 1 hour and 15 minute layover in KEF. KEF seems fairly small and the connection seems doable, assuming the flight out of YYZ is on time, but can anyone who has connected through KEF tell me their experience, especially on a short connection time? I was hoping for longer, but that was the only option going eastbound.
Thank you in advance.
Rich
RE: Connection Through Keflavik
Wed Feb 27, 2013 7:52 am
I have never flown through KEF, but the 1hr 15min connection you have is basically the standard at KEF, because of the way FI operates. FI's whole model is built around connecting passengers between Europe and North America and vice-versa, and they do this with their 757 fleet via two connection banks. The first one is early in the morning with arrivals from North America around 5:45-6:45 with flights departing to European points an hour later, hence your one hour connection time. Then in the afternoon those airplanes return to KEF around 15:00-16:00 with departures to North America an hour later.
Rest assured, your 1hr 15min connection is more than sufficient, as FI has built their whole operation around 1hr connections between Europe and North America.
novak500
Wed Feb 27, 2013 6:42 pm
Thanks B747forever, that is very useful information.
planejamie
Wed Feb 27, 2013 11:56 pm
KEF seems like a very easy connection, I've only used it as O&D but upon arrival, you clear passport control (for entry into the schengen zone so you won't do this at Paris) and you're airside again, there was no additional security check like with most airports. The airside area is relatively easy to navigate and not too much walking between gates, it's a small airport compared to CDG and YYZ. Nice airport though, and you'll like FI too!
Have a safe trip, shame you can't spend longer in Iceland on the stop over!
Sun Mar 03, 2013 6:12 pm
IIRC they have a 20 minutes minimum conntecting time in KEF so you should be more than fine.
You will need to pass Schengen Immigration in KEF by the way. Bags are checked through though and will pass Schengen customs at your final destination once you exit the baggage hall.
SRQKEF
Sun Mar 03, 2013 8:06 pm
Hi Rich,
I've never actually connected in KEF, but it's always my start point/end point when travelling abroad and I can tell you that 1+ hour is more than enough there. In fact, if you had a 30 min connection I would still say you shouldn't worry.
Also, in the case of a delay, if you arrive in KEF earlier than 15 minutes after your next flight is supposed to leave, they'll hold the following flight for you and other people connecting.
In the worst possible scenario (if you miss your flight to CDG), you shouldn't worry either. FI serve Paris 2x daily in the summer so you would just be sent on the evening flight instead and could maybe have a short break in the Blue Lagoon between flights.
Are you flying Economy or Saga Class? Not that it matters, just curious.
Regards and enjoy my country!
Sveinn
rwsea
Mon Mar 04, 2013 12:07 pm
I've never done the connection but I have several friends who've done the SEA-KEF-AMS routing. They've all shown similar concerns but have never had any issues. I asked if it was a tough connection and the consensus is that because the airport is so small, it's a really easy connection.
novak500
Mon Mar 04, 2013 5:52 pm
Quoting planejamie (Reply 3):
Thanks Planejamie, I wish I could spend more time there are well, I wanted to get up to the NE coast but time was a limiting factor.
Quoting SRQKEF (Reply 5):
That's good to know about the second flight as did not show up on the scheule when i was booking. We are flying economy, the product looks pretty good and the flight segments are not long enough (for me at least) to justify paying for Saga class. We are really looking forward enjoying your country...it really looks breathtaking.
R
sk736
Mon Mar 04, 2013 8:17 pm
I've travelled with FI LHR/KEF/BOS and return. They were the easiest connections I've ever made!
Users browsing this forum: budgetairlines2, MHG and 9 guests
