MesaFlyGuy
Delta Connecting At LGA Question?
Sat Mar 02, 2013 5:43 pm
I have wondered this for a while, but I haven't been able to find any answers.
Is it possible to connect on DL thru LGA to BOS or any of the Delta Shuttle destinations? For instance, if somebody wanted to fly JAX-BOS could they connect through LaGuardia? I tried booking it on DL's website and it only showed me connection options through ATL.
If you are able, are you on your own to get over to the MAT from the Delta terminal?
Any information is greatly appreciated! Thanks
The views I express are my own and do not reflect the views and opinions of my company.
777wt
RE: Delta Connecting At LGA Question?
Sat Mar 02, 2013 5:49 pm
There is a shuttle bus that runs between the Main terminal and the MAT. I think they come every 30 mins.
It will take a good 15 min ride from either way due to the clogging traffic around the airport caused by limos, taxi cabs, etc.
DL likes to route everything thru their main hub...ATL. I figure since they have the most flights to pretty much everywhere in DL's system.
Sligo
DL's site seems to have evolved over the years in how it offers connections. It generally discourages JFK connections these days and I havent seen an LGA connection offered up in a long while. Presumably, this is dependent on what your O&D pair is and how DL views it hub's catchment, its view on connecting capacity vs O&D, etc.
All this being said, you can usually force a connection in the focus city of your choice on Delta.com by building your itin using the multi-city tool and enter it segment by segment.
brilondon
Sat Mar 02, 2013 6:03 pm
Try booking your flight in segments, i.e. to use your example JAX-LGA-BOS.
Rush for ever; Yankees all the way!!
rwy04lga
Sat Mar 02, 2013 6:45 pm
Quoting 777wt (Reply 1):
There is a free airport shuttle bus that runs between the Main terminal and the MAT.
On the lower levels of each terminal, the light blue Port Authority bus marked 'Route A' will take you from all terminals to ...Terminal A / The MAT / The Delta Shuttle (3 different names...all the same building).
Delta runs its own shuttle from the upper levels of Terminals C and D. Any other questions? PM me.
Just accept that some days, you're the pigeon, and other days the statue
cofannyc
Sat Mar 02, 2013 9:59 pm
It has to do with the split terminal operation. DL has made the decision to not offer connections at LGA to/from the DL Shuttle because of the nature of the connection (leaving airside, taking a shuttle to the MAT, etc.)
The MCTs at LGA:
DL-DL DD SUP FLT 1 - 9998 - FLT 1 - 9998 TRM C - A
DL-DL DD SUP FLT 1 - 9998 - FLT 1 - 9998 TRM D - A
DL-DL DD SUP FLT 1 - 9998 - FLT 1 - 9998 TRM A - C
DL-DL DD SUP FLT 1 - 9998 - FLT 1 - 9998 TRM A - D
Sticking with JAX-BOS as an example, all the fare rules contain the following language:
1. NO DELTA SHUTTLE.
planeguy727
Sat Mar 02, 2013 10:45 pm
One other bit of advice - if you do choose this option you will need to re-clear security at the Marine Air Terminal. I've not done it in years, but it was quick as I remember.
I want to live in an old and converted 727...
rwy04lga
Tue Mar 05, 2013 1:18 am
Quoting planeguy727 (Reply 6):
Was quick, is quick.
