Pe@rson
1h Connection In FRA With LH?
Tue Apr 09, 2013 4:13 pm
Hi folks,
I have flown LH a few times but always on a local basis. I'm now thinking about flying them IST-FRA-LHR, but I would only have a 1-hour connection in FRA. Assuming an on-time arrival, is this likely to be achieved?
James.
wilco737
RE: 1h Connection In FRA With LH?
Tue Apr 09, 2013 4:53 pm
Quoting Pe@rson (Thread starter):
Yes, when the flight is on time, then it is managable. If the flight is delayed, it is getting tough. FRA can be bad at times. Long walks, sometimes long lines.
I personally give me more than one hour in FRA when I am connecting there.
As long as the flight is on time your chances are good to catch the flight to LHR.
wilco737
Tue Apr 09, 2013 5:46 pm
Agree as said above. But there is not much leeway... Remember you also need to pass security check in FRA.
The problem with IST is, that you usually get a bus gate in FRA. Which is obviously more time consuming.
LHR is usually departing at a B gate, which does not involve tooo much walking.
To be honest I am not too sure about paths for Nonschengen to Nonschangen transfers. I usually depart/arrive in FRA.
Maybe someone else can help. I am not sure what happens in case the bus is dropping you at A and you need to go to B. The tunnel between both terminals is Schengen (unless there is a secone one for non schengen?), so I believe this requires to take the train shuttle which runs a wagon in transit?
TS-IOR
Tue Apr 09, 2013 6:44 pm
You may check Frankfurt Airport website and you will find all tips regarding transfer. I remember they advertise a-1-hour transit time as enough... but that's what they say
aklrno
Tue Apr 09, 2013 9:35 pm
You might make it. I have done a 1 hour transit for a trip from IST to ORD but it involved a special LH bus to the special fast connection passport control, another bus, and a rushed walk to the departure gate. I'd prefer to have 2 hours. The good news for you is that there are probably a lot of FRA-LHR flights.
If you are flying early in the day, its worth a try. If you are flying at the end of the day when delays are most common and backup plans get scarce you are making a mistake.
Pe@rson
Thu Apr 11, 2013 7:46 am
Thanks, everyone, for your help. I decided against risking it and taking LH this time.
LH526
Crew
Thu Apr 11, 2013 3:11 pm
Quoting reifel (Reply 2):
FRA has special fast-lanes open for all classes of connecting flights on a tight schedule. Your flight is displayd on screens above the screening lanes tellig you if your soon-to-depart flight enables you to us said fast-lanes.
Trittst im Morgenrot daher, seh ich dich im Strahlenmeer ...
Thu Apr 11, 2013 5:14 pm
I know about these lines, about I always saw them when going from Landside to airside. Never saw them when I connected, i.e. there is none of those lines when coming down the stairs from B /Nonschengen, where there is a security checkpoint on the right which leads to the Schengen B-Gates...
AR385
Fri Apr 12, 2013 4:02 am
It´s barely doable. You can forget it if any little thing goes wrong.
