AustrianZRH
Chances Of Not Making 3 Hours Connection In IAD
Wed Apr 24, 2013 10:26 am
Hi everybody,
I have an upcoming flight in June from ZRH to SLC via IAD on UA, arrival will be 1500 hours on UA 937 connecting to UA 645 leaving 1756 hours. I actually thought that a close to three hour layover would be enough but people started to scare me that that will be a close call. So any experiences from learned a.netters in IAD, will I have good chances to make my flight to SLC or should I prepare for spending the night in IAD?
WARNING! The post above should be taken with a grain of salt! Furthermore, it may be slightly biased towards A.
visualapproach
RE: Chances Of Not Making 3 Hours Connection In IA
Wed Apr 24, 2013 10:54 am
You'll probably end up sitting around for hours in IAD wandering what all the worrying was about. Seems like plenty of time.
aloges
Wed Apr 24, 2013 11:12 am
Quoting AustrianZRH (Thread starter):
Unless your flight to IAD is heavily delayed, you should be fine. That said, it's always a good idea to carry the essentials for an unexpected night in some airport hotel in your hand luggage.
AustrianZRH
Wed Apr 24, 2013 11:47 am
Quoting aloges (Reply 2):
That is SOP when I am travelling  . Thanks for the encouraging words!
dstc47
Wed Apr 24, 2013 2:03 pm
Hope it all works out fine. Probably will.
All depends on delays at US immigration, which can be severe at IAD. Try to be off quickly to get up to the head of the line.
IAD is kind of unfriendly for a quick transit, narrow corridors with lots of passengers, with few or no moving walkways. Also go on the web and note the peculiar gate numbering convention at IAD which does not help.
airtrainer
Wed Apr 24, 2013 3:02 pm
As said above, 3h should be no problem, enjoy your flights
Life is short : eat dessert first !
LOWS
Wed Apr 24, 2013 7:07 pm
Shouldn't be a problem. It is an awful airport, that I hate flying into, but there it is.
There is also a sandwich restaurant with a very unusual name in the United C/D Terminal that is great.
Birdwatching
Wed Apr 24, 2013 7:38 pm
Also keep in mind that intercontinental flights usually arrive half an hour or even an hour earlier than scheduled. This will give you an even longer layover. If you're still worried, try sitting close to the front and try to pass some people while walking from the plane to immigration. Sometimes a couple of minutes earlier at the immigration line results in half an hour or more time saved.
Soren
All the things you probably hate about travelling are warm reminders that I'm home
usflyer msp
Thu Apr 25, 2013 3:34 am
UA has its own separate FIS in terminal C/D. If it is a UA to UA connection you should be fine...
AustrianZRH
Thu Apr 25, 2013 6:20 am
Thanks for the great input from everybody. I definitely stopped worrying now  .
Quoting Birdwatching (Reply 7):
Since girlfriend and me decided to fork out the 100$ for Economy-Plus that's a done deal. And a couple of inches of more legroom is never a bad thing  .
aloges
Thu Apr 25, 2013 8:19 am
Quoting AustrianZRH (Reply 9):
If you leg it to immigration and don't waste time in the lavatory, you'll probably beat your bags to the carousel.
rahulrahul
Thu Apr 25, 2013 8:53 pm
Yeah, it is quite possible. Just go as fast as possible in immigration, and you'll find yourself with more than an hour to spend at IAD. Good Luck!
Quoting LOWS (Reply 6):
Potbelly's ??????
A300/319/320/321/332/333/343/346 B732/738/744/752/762/763/772/773 CRJ200/700/900 ERJ140/145/170/175 MD88
LOWS
Fri Apr 26, 2013 10:07 am
Quoting rahulrahul (Reply 11):
Potbelly's ??????
It's at the very end of C, if I'm not mistaken.
zrs70
Fri Apr 26, 2013 12:05 pm
Echo other posts regarding hurrying off the plane and to immigration.
When I get off the plane, at any international arrival airport, I bypass the line or the escalator and scury up/down the stairs. Usually gets me in front of 2 dozen right there.
18 year airliners.net vet! 2000-2017
