Max Q
Suggestions For Economical RTW On Specific Route?
Sat Aug 03, 2013 6:21 am
I need to travel on the following legs non stop in about a month, Tampa to London, London to Hong Kong then back via LAX or SFO then non stop to Tampa.
Ned to stay about 3 days in London, 3-4 weeks in Hong Kong.
Anyone have suggestions for the most economical itinerary, and / or where to start looking ?
lugie
RE: Suggestions For Economical RTW On Specific Rou
Sat Aug 03, 2013 9:39 am
I think a good source is the flight booking site at Expedia: http://www.expedia.com/?rfrr=Head:Nav:Multi:Home
Here you can choose between one way, roundtrip and multiple destinations. The latter should be suitable for you, you can search up to 6 single flight legs, with a new departure date for each of them.
I hope I could help you
Q400 E175 CRJ9 A319 A320 A321 A332 A333 B733 B738 B788
X3 LH 4U TP US YX SN EI LA
FRA STR HAM TXL ACE BRU BLL DUB MAD OPO LIS FNC AMS PHL RDU LGA CLT
fallap
Sat Aug 03, 2013 11:01 am
Aeroflot provides cheap intercontinal fares, you should try checking out their prices from LHR to HKG
Grease monkey buried head to toe inside an F-16M
redzeppelin
Sat Aug 03, 2013 2:13 pm
Although I haven't used it much with international routes, I really like flights.Google.com for searching. It is pretty good at finding off-the-radar connections -sometimes including multiple airlines- that can save you some money. The amp search option is helpful for finding fares to alternate airports, but it sounds like you know pretty well where you need to go.
Sat Aug 03, 2013 4:53 pm
Cough cough.
This post should be in the forum 'TRAVEL, POLLS AND PREFS'
Please do come back to the Trip Report forum when you have done you lovely RTW tour, and give an account, with lots of photos of foods, toilets and IFE screens.
RyanairGuru
Sun Aug 04, 2013 2:29 am
As mentioned, you've posted on the wrong forum.
Expedia and Orbitz are both surprisingly good for cheap RTWs. Build the trip as a multi-leg itinerary. If you're not choosy about airlines etc then obviously get a better deal, by plugging in some dummy dates around the information you provided I'm seeing $3750 on Orbitz for AA-CA-DL (bizarrely, three different alliances!) If you play around with dates you might be able to get something cheaper as I have seen RTW fares for $2800 before on these websites, but you are booking close in so that's probably likely.
If you are happy dealing with an agent rather than doing it yourself online, then I would recommend Flight Center. I can't promise anything but they sometimes have stunning RTW deals http://www.flightcenter.com/
Worked Hard, Flew Right
usflyer msp
Sun Aug 04, 2013 3:00 am
The cheapest I am seeing is $2426 on AA, MU, US combo on hipmunk...
Sun Aug 04, 2013 8:49 am
I would suggest using Kayak and booking everything as one ways and not using multi city search. Kayak can also show you flexible dates, I believe staying 1 day more or less is not an issue in your case.
Airlines cheap for one ways:
TPA-LON:
Airberlin (alhough from MIA or RSW)
Turkish (usually via Canada or US Gateway and huge detour in IST), this one you can use from TPA as well)
Transaero (from MIA via Vnukovo)
Will cost you around 600 EUR
LON-HKG:
Vietnam (via SGN or HAN)
MH (via KUL)
TK (via IST)
will cost you around 500 EUR
HKG-TPA:
MH (via KUL) to LAX (approx 350 EUR) and then another ticket LAX-TPA on whatever (approx 100 EUR)
Makes you a total of 1500 EUR which is approx 2000 USD and I am sure this you can try to get even a bit lower if taking more time and trying different dates, routings etc... I.e. instead of booking TPA-LON on one ticket, you may also book JFK-SNN-LON one ticket with EI at approx 330 EUR (or even cheaper with Norwegian's long haul 787 via Scandinavia) and then add a separate TPA-NYC with Delta at approx 60 EUR, which makes you save 100 EUR more, you get the idea...
TPAfan
Sun Aug 04, 2013 7:00 pm
Well, since you are staying in London for three days, can you switch airports? BA flies to LGW daily, non-stop from TPA on the 777-200 ER. Then, traveling to HKG, you could fly from LHR to HKG, and then via LAX, you could fly to TPA on DL. I generally look at orbitz, it gives you multiple options, typically the most affordable, but I also check on the airlines websites. What dates are you planning, or what general time (like month). Just with that, it would be a bit easier to check out, and I could give you suggestions if you need any.
Edit: I didn't see you posted saying, "in about a month." Okay, thanks for the first date.
[Edited 2013-08-04 12:13:07]
Edit again: first searches ran, TPA-LON (cheapest option I found was around $650 (that involves flying B6 to BOS, and taking Icelandair from there, 2 stops total). Nonstop to LGW on BA from TPA looks around $1750, which is expensive. As someone else recommended, if you are trying to go as cheap as possible, you could book separate tickets, and fly from JFK on Norwegian air shuttle, which is extremely affordable.
[Edited 2013-08-04 12:20:44]
usflyer msp
Mon Aug 05, 2013 3:39 am
Keep in mind, if you book separate tickets you may run into baggage allowance issues on some sectors as European and Asian carriers are often much stingier with baggage if you itinerary does not involve the Americas...
usflyer msp
Mon Aug 05, 2013 4:23 am
FYI,
Condor is selling SFB-LGW nonstops for $250 o/w...it is pretty much impossible to beat that...
aklrno
Mon Aug 05, 2013 7:20 am
Have you looked at RTW fares on the Star Alliance or One World pages? Sometimes they can be good. You can mix airlines among the groups, add stopovers, change dates.
