bjorn14
Your Dream Midsize Turboprop
Tue Aug 06, 2013 8:02 pm
With 50-seat RJ flying slowly being cut by the majors and the fleet of midsized (30-40 seats) turboprops reaching their end of life cycles there will be a huge gap in the market from 19-seaters to 70-seaters (with ATR the only maker of a 50-seat TP) If you could design the NG TP what would you have in itP
Here is my wishlist (no particular order)
Glass cockpit
Combo pax/cargo door
Galley w/oven(s)
Lavaratory
6J/30Y 36"/32" seat pitches; power ports
1,200+nm range
Noise/vibration reduction technology
800m/2,650ft. MinTOL
5-blade carbon fiber propellers
6'2"/1.9m cabin height; mainline overhead bins
365 mph cruise speed
WiFi and/or seatback IFE
Under US$20MM
and now your dream------
"I want to know the voice of God the rest is just details" --A. Einstein
masseybrown
RE: Your Dream Midsize Turboprop
Tue Aug 06, 2013 8:12 pm
Speaking as a passenger, the old Electras were pretty nice. I think in all-first config they seated about 64 pax, maybe around 90 for the two-class versions. It was a nice ride. I'd welcome the equivalent back.
MesaFlyGuy
Wed Aug 07, 2013 2:23 am
Mine would be a two-class Q400 with AVOD, WiFi, and lower-mounted wings, so you can see out the windows better.
The views I express are my own and do not reflect the views and opinions of my company.
Devilfish
Wed Aug 07, 2013 5:32 am
Quoting bjorn14 (Thread starter):
Save for a few deviations, isn't that basically this?.....
Photo © Terence Li
.....and it's not exactly flying off the assembly line.....
Under US$20MM
Good luck!
[Edited 2013-08-06 22:46:28]
bjorn14
Wed Aug 07, 2013 2:13 pm
Quoting Devilfish (Reply 3):
Your half right...its a mixture of an ATR42-600 and a Do328
Good luck!
The current 42 sells for US$14MM so I should be good.
PlymSpotter
Wed Aug 07, 2013 6:57 pm
I would suggest there will be demand for two aircraft families in the future:
30 and 50 seat turboprop:
- Four abreast seating
- Average cruise speed
- RFFS Cat 3 for the 30 seater and 4 for the 50 seater
- STOL performance for sub 800m runways
- Proven but rugged technology
80, 110 and 140 seat turboprop:
- 5 abreast seating
- RFFS Cat 5 for the 80 seater, 6 for the others.
- STOL performance from sub 1,200m runways
- Proven technology
Dan
Devilfish
Sat Aug 10, 2013 1:24 am
Quoting PlymSpotter (Reply 5):
Wish Bombardier would be bold enough to launch a completely updated/upgraded Q200...    ...
Photo © Andy Graf - VAP
Photo © Markus Mainka
PlymSpotter
Sat Aug 10, 2013 1:51 pm
Quoting Devilfish (Reply 6):
They would be better to develop a clean sheet 30-50 seater and create a larger family with C Series commonality to replace the Q400. The Q200/300 are good aircraft, but they are a fair bit more plane compared to the ATRs and I'm not convinced that a Q200NG alone would work, you would need a 50 seater too.
Dan
Devilfish
Sat Aug 10, 2013 3:37 pm
Quoting PlymSpotter (Reply 7):
Photo © Stephen Liard
Photo © Andy Vanderheyden
I think ATR has the 50+seat TP market covered but they're not making much of a headway despite being the sole OEM offering a new generation airframe in that segment. Competing with ATR there and coming up with a completely new, bigger TP as the market suggests might be too much for Bombardier. As it is, they already have their hands full with the much delayed CS100 first flight (not to mention CS300). Continuing unchallenged in the Q200 niche (though not very lucrative) might be all BBD and its suppliers could manage at the moment. They could then go on from there when conditions are better.
bjorn14
Mon Aug 12, 2013 3:14 pm
From what I understand the big problem with the '42' is that it has the same economics as the '72' I was hoping I could fix that by making it lighter, more room for cargo, more carbon fiber parts.
RussianJet
Mon Aug 12, 2013 3:53 pm
Under US$20MM
Good luck!
- Proven technology
How about an AN-140?
Plym, I assume you've flown that type probably more than once, how is it? Admittedly it has one too many blades per engine, but it looks lovely.
✈ Every strike of the hammer is a blow against the enemy. ✈
PlymSpotter
Mon Aug 12, 2013 8:33 pm
Quoting Devilfish (Reply 8):
Part of the problem is that the 42 is at the wrong end of the scale of economy. A 30 and 50 seater joint development would result in a more competitive 50 seater. But another big part of the problem is the 72's performance - it has very similar STOL capabilities to the 42 and is slowly hoovering up the 50-70 seat market. Hence a new 30/50 seat aircraft would have to beat it.
In time that wouldn't be an issue in my opinion, the C Series might be guzzling resources but the Q400 and CRJ programs are not exactly booming.
Quoting bjorn14 (Reply 9):
The economics aren't so much the problem, rather that the 72's performance has improved so much that it is taking market share away from the 42.
Quoting RussianJet (Reply 10):
Yeah I've flown a few of them, it's a fine aircraft actually - comfortable cabin, nice ride and looks great inside and out. Shame it didn't get the production support required for it to be a serious contender.
Dan
Goldenshield
Tue Aug 13, 2013 12:02 am
It'd be nice if Embraer looked into building a new E-120, based on the E-145 frame, with pusher props, but they have SJS, and aren't looking back.
