flyhighunited
UA870 Diverted To HNL
Wed Jun 18, 2014 11:13 am
Hi guys - does anyone know why UA870 was diverted to HNL today?
http://flightaware.com/live/flight/UAL870
catdaddy63
RE: UA870 Diverted To HNL
Wed Jun 18, 2014 2:48 pm
Doesn't look like a diversion, looks like a planned stop. Crew rest issue? Tech issue? Aircraft was two hours late leaving SYD.
av8ornta
Wed Jun 18, 2014 2:55 pm
Looks like a fuel stop in the notes on shares
LAXintl
Wed Jun 18, 2014 2:58 pm
HNL was intended destination.
HAL
Wed Jun 18, 2014 3:05 pm
This may open a big can of controversy, but I'm pretty sure it's planned because that SYD-SFO route is right at the limit of the plane's range. Throw in heavier than average load, or stronger than average headwinds, and they'll have to make a tech stop in HNL.
For anyone who has read my posts in the area before, you know what I'll say next. If you are looking at an airplane's published range and saying "But the 777 can do that route no problem", the truth is that published range has exactly zero to do with real-world range. Throw in strong winds or heavy loads, and none of today's airliners will make their advertised range.
I've talked to a couple of UA pilots who were on my jumpseat about this very issue (and aircraft choice). They both just shook their heads and said something to the effect of "Yes, they are planning on doing tech stops, and no, it's not the right aircraft for the route."
But if UA wants to fly SFO-SYD, their choices are pretty limited in aircraft type if they don't want to use the 744. I guess they'll just do what they can with what they have.
HAL
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
LAXintl
Wed Jun 18, 2014 3:08 pm
Quoting HAL (Reply 4):
Stop had nothing to do with payload issues.
usflyguy
Wed Jun 18, 2014 3:13 pm
A planned fuel stop that is going to take 2 hours and 40 minutes?!
My post is my ideas and my opinions only, I do not represent the ideas or opinions of anyone else or company.
HAL
Wed Jun 18, 2014 3:17 pm
Quoting LAXintl (Reply 5):
What was the reason?
HAL
LOWS
Wed Jun 18, 2014 3:22 pm
Isn't the 777 going to be replaced with a 789 when more are delivered?
LAXintl
Wed Jun 18, 2014 3:23 pm
FAR117
Quoting usflyguy (Reply 6):
Allow for pax FIS processing.
777Jet
But the winds are in favor departing SYD - the head winds become more of an issue departing the USA for SYD. Also, SFO is slightly closer than LAX IIRC. So, SYD-SFO should be the easiest routing out of: SYD-SFO, SYD-LAX, SFO-SYD and LAX-SYD...
DC10-10/30,MD82/88/90,717,727,732/3/4/5/7/8/9ER,742/4,752/3,763/ER,772/E/L/3/W,788/9,306,320,321,332/3,346,359,388
FriscoHeavy
Wed Jun 18, 2014 3:41 pm
It really surprises me the 77E had a fuel stop East-bound from SYD-SFO.
Are these the UA or CO birds? If they are UA, would the GE powered CO 777s fare a bit better?
FriscoHeavy
roseflyer
Wed Jun 18, 2014 4:05 pm
Quoting FriscoHeavy (Reply 11):
It could be that they had to place something like a hydraulic pump or brake etc on MEL. That would limit the maximum takeoff weight of the plane. There are not many 777 spare parts stored in Sydney, so a takeoff weight restriction could cause the fuel stop. It is better than a cancellation. There are many many items that can limit the range if an airplane. Even crew oxygen could cause an altitude restriction which reduces range. You never really know.
warreng24
Wed Jun 18, 2014 4:19 pm
SYD-SFO/LAX is currently operated by sUA birds. These are the lower-rated PW 777's.
The CO 777's are GE powered and have more capability. These are the birds that should be flying this route, IMHO.
FlyHossD
Wed Jun 18, 2014 4:21 pm
As far as I can tell, these flights are operatred by sUA 777s. I believe the sCO birds can carry slightly more load, but I'm not sure that would solve the issue.
I doubt that UAL will spring for 777LRs, so this situation will likely continue unless UAL puts 744s back on the route.
raggi
Wed Jun 18, 2014 4:53 pm
AFAIK, the pmUA 77Es were upgraded to the 656KLbs MTOW, highest available for the 77E, and same as the GE pmCO 77Es.
The GE90 might have slightly better fuel burn than the PW4090, but the pmUA birds should do the job just fine.
Stick & Rudder
fun2fly
Wed Jun 18, 2014 4:54 pm
Quoting warreng24 (Reply 13):
The UA birds are the ones flying this due to first class which brings me to the point that I cannot believe the 789's don't have a first class and put on the SYD runs. It's a long time with stops with these UA birds until 2018 when the A350 arrives.
tkukucka
Theses are the PMUA 777s withe the the 3 class config. Even though being PW powered aircraft the difference in TOW is 2t I believe don't quote me on that. If UA ever decides to put F on the UA 789s then yes I'm pretty sure LAX/SFO-SYDNEY will go to the Dreamliner. But I believe the UA789s don't arrive till 2016.
EK413
Wed Jun 18, 2014 5:01 pm
Probably a stop due to crew exceeding hours considering the flight was delayed ex-SYD?
EK413
Good evening, ladies and gentlemen. We are tonight’s entertainment!
roseflyer
Wed Jun 18, 2014 5:02 pm
Quoting fun2fly (Reply 16):
There haven't been fuel stops on the LAX-SYDNEY southbound flight which is the longest flight. I suspect this flight's stop was due to crew hour limits (the flight was delayed a few hours) or more likely a payload restriction caused by a deferred maintenance item. The GE 777s have very little added range. If SYD has bad weather and requires carrying significant extra fuel for an alternate then we might get fuel stops, but otherwise I don't think this flight is representative of poor fleet planning.
UA444
Mon Jun 23, 2014 8:51 am
UA flew the 777s to AKL back in the day just fine, and the 777 did sub for the 747 a couple of times in the past. These birds have no problem making the trip. And the reason why they are using UA 777s and not the ex-CO ones is because the spares and expertise for the PW is all in SFO and LAX, where none of the ex-CO 777s are based. There's also the fact the ex-CO 777s don't have F, which SYD is a VERY profitable F route. The PW 777 is a great airplane.
[Edited 2014-06-23 01:52:46]
Qantas744er
Tue Jun 24, 2014 5:17 pm
Stick & Rudder
Quoting raggi (Reply 15):
They were up-rated to 648k from 640k. The PW4090 thrust would not be sufficent for 656k takeoffs under most circumstances.
You live and you die, by the FMA
penguins
Tue Jun 24, 2014 6:19 pm
Quoting tkukucka (Reply 17):
UA takes their first 789 this summer.
DocLightning
Tue Jun 24, 2014 6:36 pm
Quoting FlyHossD (Reply 14):
The 787 might be a good choice for this route. Once the A350s are in service, they might also be a good choice.
SFO-SYD is a tough route even for the 744. There's alot of water, not a lot of diversion options that don't require hours of flight, and variable winds.
However, the 772 should not have trouble making this route. It rarely does.
-Doc Lightning-
-Carl Sagan
S75752
Fri Jun 27, 2014 1:47 am
The 772 sounds like it regularly handles other crazy stuff like EWR - BOM, HKG, though those are likely pmCO. How many times has a UA (pmCO or pmUA) 772 actually had to divert on any route for fuel/load reasons (Not so much looking for a straight number, mostly just wondering about any times in memory that come to anyones mind)
Quoting UA444 (Reply 20):
Not sure how much of a comparison AKL is to SYD, considering that it's an almost ~900 Mile difference out of either SFO or LAX. I'm not arguing against that the 772 can do it easily, just uncertain of the AKL SYD comparison. (NZ currently does use 772ER on the AKL-SFO last I saw.)
RyanairGuru
Fri Jun 27, 2014 2:28 am
I agree, but with the 787s going to sCO it makes sense to keep them in a 2 class configuration. Those A350s can't arrive soon enough, though.
Quoting Roseflyer (Reply 19):
The only real "bad weather" that SYD contends with is fog, and only on maybe three mornings over an entire winter. For those obscure occurrences that SYD is closed and they don't have sufficient reserves to circle, they can gas-and-go at BNE.
While UA could well be taking a hit on cargo payload by using the 77E, diversions due to head-winds would be so rare as to barely be a consideration in route-planning.
Worked Hard, Flew Right
roseflyer
Fri Jun 27, 2014 4:02 am
Quoting RyanairGuru (Reply 25):
If fuel for Melbourne has to be carried, then there are payload restrictions on the 777. Diversions due to fog only happen a few times per year, but the threat of it when they are doing the flight plan 18 hours before arrival causes the weight restrictions. This is true for 747s and 777s. The diversion fuel is the issue since it eats into useable payload and is needed to be carried just in case on occasion.
RyanairGuru
Fri Jun 27, 2014 4:49 am
Quoting Roseflyer (Reply 26):
I'm aware of that
But nobody in their right mind would use MEL as a diversion for SYD when coming from North America
It is 500mi further than SYD, whereas BNE is 500mi closer.
