Slug71
Safran inaugurates open rotor test program
Tue Oct 03, 2017 10:29 pm
Looks like ground tests have begun,
Safran is celebrating today the success of the first ground tests of the Open Rotor demonstrator engine in Istres, southern France.
https://www.safran-group.com/media/safr ... e-20171003
SCAT15F
Re: Europe Shelves Open-Rotor Flight-Test Demonstration
Wed Oct 04, 2017 3:00 am
Good! ...Forget the short-sighted "Clean Sky" leadership. Safran knows this is the future. Damn the torpedoes and full speed ahead! (hopefully)
parapente
Tue Oct 10, 2017 7:29 am
Thx for the Saran link -very interesting.Was also interesting to note that they were also investigating in parallel a shrouded route for the very reason mantioned earlier i.e. That it could be integrated on existing/conventional plane designs.I think this is a major point.
It seems that Rolls too have put their OR work to sleep for the moment and concentrating on the 'Ultra'.Perhaps for the same reasons.
In a way I was disappointed to note that a new a/c company funded by Boeing capital building 10-20 seater hybrid a/c was also using the shrouded fan (electric) route.I guess it's the noise thing again.
I raised this simply as OR might have had a future for electric/hybrid a/c where every drop of efficiency counts (range).Personally I hope it has,I think that's (hybrid) the right arena for CR OR electric drive engines.
Egerton
Tue Oct 10, 2017 7:10 pm
I wonder if the continuing Silvercrest issues have drained both Safran financial and engineering resources to the point that all hands were needed to fix Silvercrest?
WIederling
Tue Oct 10, 2017 9:06 pm
IMU it is the EU research program that was discontinued not the Safrane test item program.
I find this a bit strange.
Murphy is an optimist
r2rho
Wed Oct 11, 2017 2:28 pm
My reading of this between the lines is that Airbus didn't want to play along anymore, and thus the EU research program was cancelled due to lack of a platform for flight tests.
The cancellation most certainly did not come from Safran, who is actually proceeding with the program on its own, as we can observe.
KarelXWB
Re: Safran Inaugurates Open-rotor Test Program
Wed Oct 11, 2017 2:42 pm
Just to be clear, the open rotor demonstrator under the European Clean Sky project has been canceled.
European Clean Sky project shelves open rotor flight-test demonstration
Safran is doing its own research.
KarelXWB
Wed Oct 11, 2017 2:46 pm
As for the Safran demonstrator, note that it is a scaled down version.
Here's a short video of the demonstrator in action:
https://twitter.com/SAFRAN/status/915166463140536321
ro1960
Re: Safran inaugurates open rotor test program
Fri Oct 13, 2017 9:24 pm
Just curious and maybe naive but wasn't this called UDF or Propfan some 30 years ago? Tested on a 727 and on a MD-80? It never went beyond prototypes. Why? And why would it work now?
You may like my airport photos:
https://www.flickr.com/photos/aeroports
WIederling
Fri Oct 13, 2017 9:43 pm
It made your ears come off.
the noise was unacceptable even for the timeframe "back then".
If you can reduce the noise you have a potential winner.
No idea how much tech carried over from the abortive UDF design.
kurtverbose
Sat Oct 14, 2017 5:33 am
I read that when RR looked at open rotors they looked at the Allison experience (they took over Allison who had worked with P&W on the propfan), and weren't very impressed with their attempts at noise attenuation. Specifically, making the rear rotor smaller than the front makes a big difference. I think I read that they can solve the noise problem at current noise laws, but probably not if noise laws become stricter.
The really big issue facing open rotors is airworthyness. I've not read any conclusions about how you get a supersonic fan blade with no containing shrowd through certification.
Sat Oct 14, 2017 6:34 am
I can't see how an uncontained supersonic fan blade would meet with much resistance. ;) :duck:
lightsaber
Sat Oct 14, 2017 3:35 pm
Open rotors are fascinating. Just remember the slower cruise speed than a GTF. They're benefit is they give you a higher bypass ration without the weight of a nacelle. But without a nacelle, blade tip mach number is limited which means cruise speed is limited more than with a nacelle.
Business jets routinely fly at Mach 0.85 +/- 0.07
Commercial jets travel at Mach 0.75 +/- 0.03.
Propfans will be at Mach 0.7 +/- 0.03.
Turboprops are down at Mach 0.65 +/- 0.3
Propfans are the halfway point between turbofans and turboprops for flight speed and efficiency. They're ideal for shorter hop markets such as Europe or the NorthEast US. But they won't be great for 1,500nm+ missions. At some point the slower speed adds up in costs.
And yea, I've read some pretty outlandish claims on propfan cruise speeds matching turbojets. Really? That is someone who doesn't understand shock wave generation off airfoils (the blades pushing the air). If there were such a development in airfoil technology, you would first see a Mach 0.95 business jet.
Please don't get me wrong, I see a spot in the market for propfan's. But as someone who lives in the Western US where a flight is longer, I live in a market that desires speed.
I also know of technology being developed for the next generation GTF. The propfan will not be competing against today's engines, but a RR or Pratt improved GTF. The same airfoil technology that enables the propfan will help make a GTF more efficient.
I do believe the Silvercrest is quite a distraction for the engineering teams. They have had two bad cases in a row (they fixed the SAM146 early enough to keep it out of public discussion). I'm trying to figure out what is up with the recently disclosed compressor issue:
https://www.ainonline.com/aviation-news ... ssor-issue
Safran has to promise Dassault something to keep the 5X alive:
https://uk.reuters.com/article/us-dassa ... KKBN1CG2NH
Lightsaber
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
Brixerl
Tue Oct 17, 2017 6:19 pm
Can somebody explain me the background to this :0)
1988?
https://www.youtube.com/watch?v=1BMNaXc1rL8
Respected members: airmagnac, ap305, enzo011, KarelXWB, keesje, lightsaber, longhauler, masi1157, mfranjic, parapente, Polot, Revelation, rotating14, seabosdca, speedbored, Stitch, tommy1808, Wiederling, zeke
ro1960
Tue Oct 17, 2017 9:56 pm
1988?
This explained further up in the thread.
SCAT15F
Wed Oct 18, 2017 4:38 am
Lightsaber
Well, NASA says otherwise. Open rotor/turboprops maintain their efficiency advantage over any type of turbofan at speeds up to and slightly exceeding mach .90. This was demonstrated in the wind tunnel as far back as the 1970's and proved during the 1980's with in-flight demonstration using NASA's full scale advanced turboprop flying at speeds up to mach .89, with mach .85 being the sweet spot.
Its all right in the ATP project report PDF which can be found online
Brixerl
Wed Oct 18, 2017 5:06 am
ro1960 wrote:
1988?
Thanx - and sorry, I have overlooked that.
parapente
Wed Oct 18, 2017 10:48 am
OR is an interesting technology.Both Safran and RR have looked into it deeply.Clearly there are 2 major hurdles.Noise.If they can't overcome this it is dead.However I do recall RR stating that this could (at least in part) be overcome.The other is 'Bkade out' safety.This required radically different airframes.Thus a huge investment.
In normal circumstances this would probably be enough to kill it.However we (will) live in different times.
I think we have to imagine ourselves in 2030/40.By then a hoast of major countries and cities will have banned ICE automobiles.To do that clearly busses and trucks will also have had to comply.Power generation will also be 'clean' (Nuclear,wind,solar).So the spotlight will be firmly on the still existing big 'polluters '.Aircraft and Shipping.
For shipping I think the end of the use of heavy sulphur fuels (bunker oil-tar!) will be a certainty.Not sure what more they can do beyond using 'clean diesel '
So the spotlight will fall firmly on aircraft which do their polluting in the worst possible place.In that scenario I can see OR being the only way forward due to its unbeatable sfc.But as the article states the first stage will be ultra high bypass (GTF) shrouded fans -which can be employed on 'standard'designs of aircraft.
r2rho
Tue Oct 24, 2017 8:11 am
Plus, back then oil suddenly became cheap cheap cheap. So, why go through all the trouble of tackling the technical challenges of open rotors, for a comparatively small financial savings in fuel? With 100$ oil, the balance changes. But we are now too far below that, which is likely one reason why Airbus stepped out.
lightsaber
Wed Oct 25, 2017 4:24 am
Lightsaber
I'd like to see the link showing what you claim. It is counter to what I know of shockwave mitigation. To fly at Mach 0.9, the blade tips must be at Mach 1.3 or more to have an average net thrust. That has entered the range where shrouded fans have higher efficiency than unshrouded fans even after the weight and drag penalty of a nacelle.
I saw the prior data. Open rotor efficiency dropped off in the real world at Mach 0.73 or so. Please point me to new data and I will happily change my opinion.
Lightsaber
JoeCanuck
Thu Oct 26, 2017 9:13 pm
Lightsaber
Lightsaber
Regardless.....there isn't a chance in hell that supersonic OR blades would make noise regs.
I suspect we'll be stuck between slow and quiet, and fast and noisy.
What the...?
CowAnon
Fri Nov 03, 2017 1:03 am
I think this is the document in question: Advanced Turboprop Project, NASA SP-495 (1988).
Page 2 has a figure from 1974 showing that a single-rotating propfan could have an installed efficiency higher than a turbofan from Mach 0.6 through 0.85 (about 76% vs. 70% at M0.85). On page 75, a figure shows a contra-rotating propfan bettering that, at 82% net efficiency. The discussion of blade design concludes that thin blade tips with at least a 30-degree sweep keeps air flow from going supersonic and reduces noise at higher speeds (figure 5 on page 7).
Regarding noise, Safran already claims the problem is solved (https://www.ainonline.com/aviation-news/air-transport/2017-10-04/safran-inaugurates-open-rotor-test-program):
Wind tunnel tests carried out in 2013 helped solve the noise challenge, one of the main hurdles in open-rotor development. "Our demonstrator has the same sound levels as a Leap, thanks to an optimization of the aerodynamics of fan blades," explained Safran research and technology director Stéphane Cueille. The company has not scheduled flight tests.
CowAnon
Mon Mar 05, 2018 8:06 am
From https://www.flugrevue.de/flugzeugbau/tr ... tor/747206 (in German): testing was completed in December. Also, Safran says their engine can be used at speeds up to Mach 0.75.
I don't work or have training in the aviation industry, so I can't argue about technical details very much, but why would GE as of 2013 (https://www.faa.gov/about/office_org/he ... Report.pdf) still be working on M0.78-0.80 engines targeting narrowbody planes if they didn't have evidence that open rotors were feasible at those speeds?
Unlike designs of the 1980’s in which the blades were only marginally satisfactory for either high flight speed performance or low flight speed acoustics, modern analytical tools have enabled current designs to meet aggressive acoustic goals while retaining the performance advantage of low disk loading, even at flight Mach number up to 0.80.
The Gen2A+B results were analytically constructed by combining direct measured results of Gen2A with the measured effects of technology “+B” with respect to the tested Gen1A baseline design. A Gen2A+B design is projected to meet the noise goal of 15-17 EPNdB cumulative margin to Chapter 4 on the NASA modern open rotor aircraft model while coming within 0.5% of the Mach 0.78 max climb net efficiency goal for 26% fuel burn benefit relative to CFM56-7B powered aircraft. These projections do not include additional improvement opportunities demonstrated during the test campaign with regard to pitch setting, pylon blowing, and blade design that can be employed to further advance open rotor technology.
CowAnon
Fri Aug 31, 2018 7:14 pm
Aerospace America asked the Safran research and technology VP about the open rotor project in last month's issue:
Jerome Bonini (https://aerospaceamerica.aiaa.org/depar ... innovator/) wrote:
Bird strike test
We have composite blades — the way the propeller blade cracks is different from a metallic blade. These blades are more robust than metallic blades. We can imagine a different way to monitor them and to replace blades before failure. The main event we have to demonstrate is the bird strike event. We intend to perform it in the next two years in Villaroche where we have a dedicated test bed for ingestion test of fine blades.
Timetable
Regarding the flight test, that should be 2024-2025. We expect the beginning of the development in 2030 and an entry into service in 2035.
So Safran will be flinging birds at the test engine for two years, :duck: and they added another five years to the projected service entry date. :( I wonder whether the development actually requires that much more of a cushion, or if the company is aligning its timeline to the year it believes Boeing or Airbus will debut a clean-sheet narrowbody? It would be nice if COMAC, Mitsubishi, Irkut, or someone unexpected would step up and build a propfan earlier … they'll need some sort of edge over A/B's existing product to actually take market share.
Slug71
Sat Sep 08, 2018 4:36 pm
Bird strike test
Timetable
Seems like a very long development/testing window considering they already have a demonstrator going.
I think it's more likely to see EIS on a ATR or Q400 replacement, than a narrowbody though.
TSS
Sat Sep 08, 2018 5:56 pm
Bird strike test
Timetable
I'd bet on a dramatically more fuel-efficient CRJ replacement since the CRJ airframe is perfectly suited to the bolt-on installation of open rotor engines and a more fuel-efficient choice that's still technically a "jet" for relatively short flights could reignite regional jet sales for Bombardier.
Slug71
Sat Sep 08, 2018 6:02 pm
That's a good possibility too. Even a ERJ replacement.
ZaphodHarkonnen
Sun Sep 09, 2018 8:44 pm
With no pressing need I imagine they're going at whatever the cheapest route is for this bit of R&D. Even if it means it takes a while before we start seeing stuff flying.
Users browsing this forum: Florianopolis, Starlionblue and 12 guests
