Balerit
6 wheel bogey
Wed Nov 22, 2017 10:54 am
Which was the first aircraft to use a six wheel tandem bogey?
Licensed Aircraft Maintenance Engineer (retired).
KingOrGod
Re: 6 wheel bogey
Wed Nov 22, 2017 11:03 am
Dagsê...
Tu-154? first flight 1968...
Balerit
Re: 6 wheel bogey
Wed Nov 22, 2017 12:33 pm
KingOrGod wrote:
Dagsê...
Morê, I see the AN22 was built in 1963 and had 6 wheel bogies, any others? Latest aircraft are the B777 and A350-1000.
Balerit
Re: 6 wheel bogey
Wed Nov 22, 2017 12:34 pm
TU 154
dragon6172
Re: 6 wheel bogey
Wed Nov 22, 2017 1:08 pm
AN22 have two 6 wheel bogies? Or is it six 2 wheel bogies?
Phrogs Phorever
KingOrGod
Re: 6 wheel bogey
Wed Nov 22, 2017 1:52 pm
Balerit wrote:
KingOrGod wrote:
Dagsê...
I always thought that one (An22) was 3x2 not 1x6...
kurtverbose
Re: 6 wheel bogey
Wed Nov 22, 2017 2:13 pm
And the A380, which has both 4 and 6 wheeled bogies.
Makes me ask the question, will there be an 8 wheeled bogie?
Re: 6 wheel bogey
Wed Nov 22, 2017 3:28 pm
IIRC Tu-144 had 8 wheel bogies back in the 60s....
DH106
Re: 6 wheel bogey
Wed Nov 22, 2017 3:58 pm
Weren't they 4 wheel bogies with a double tire on each?
Think they were designed like that to be thin enough to retract edge on into the nacelles.
...I watched c-beams glitter in the dark by the Tanhauser Gate....
kurtverbose
Re: 6 wheel bogey
Wed Nov 22, 2017 4:32 pm
Maybe we should talk about axles rather than wheels?
WIederling
Re: 6 wheel bogey
Wed Nov 22, 2017 4:55 pm
That is 3 pairwise wheeled individually articulated gear legs per side.
compare with the C160, C17, A400M, AN124, AN225 ...
Murphy is an optimist
Armadillo1
Re: 6 wheel bogey
Wed Nov 22, 2017 4:56 pm
WIederling
Re: 6 wheel bogey
Wed Nov 22, 2017 4:58 pm
LH707330
Re: 6 wheel bogey
Wed Nov 22, 2017 6:05 pm
Why did the Tu-144 need twice as many wheels as Concorde, was the idea to fly from fields with much lower pavement loading like with the 154?
Florianopolis
Re: 6 wheel bogey
Thu Nov 23, 2017 5:28 am
The B-58 also had that design, and it was because thin high-speed wings don't give you much room to hide landing gear, so you have to get creative. The SR-71 also has a bunch of small tires, because there's no room put big fat ones.
DH106
Re: 6 wheel bogey
Thu Nov 23, 2017 4:39 pm
Great graphic! - but doesn't make clear if the tires are on seperate wheels or not. Anyone know?
Armadillo1
Re: 6 wheel bogey
Thu Nov 23, 2017 5:07 pm
it is only your fantasy about "non-separated wheels"
what you mean in word "wheel"?
more pics here
http://fotografersha.livejournal.com/636256.html
you can see wheels individualy.
big axis contains big fans for brakes
DarkSnowyNight
Re: 6 wheel bogey
Sat Nov 25, 2017 2:17 am
more pics here
What a great find. I had no idea that was a 2-3 cross section either.
Much like a GE90, I'm a huge fan of Big Twins...
Balerit
Re: 6 wheel bogey
Mon Nov 27, 2017 6:48 pm
more pics here
I agree, good find and looks like a lot of hard work went into restoring that plane in difficult conditions. :thumbsup:
WIederling
Re: 6 wheel bogey
Tue Nov 28, 2017 10:56 am
[quote="Armadillo1"
[/quote]
IMU what was asked is:
Is each tire an independent unit with individual rim and bearing or
is it a "unit piece made out of rim and spacer segments fitted with two tires each.
to check: can you independently rotate the tires on one axle stub?
VSMUT
Re: 6 wheel bogey
Tue Nov 28, 2017 11:31 am
WIederling wrote:
[quote="Armadillo1"
to check: can you independently rotate the tires on one axle stub?[/quote]
I would think that they rotate independently. It would affect the aircraft's ability to taxi properly if they couldn't.
Balerit
Re: 6 wheel bogey
Tue Nov 28, 2017 12:54 pm
Armadillo1
Re: 6 wheel bogey
Tue Nov 28, 2017 9:03 pm
understood
thank you. its a good question.
i ask that guys about it, let's wait for they answer.
wheel model name is KT-160A, some time called "doubled wheel", so i think is is one axis with 2 tyres.
more pics:
http://www.reaa.ru/cgi-bin/yabb/YaBB.pl?num=1408374309
also found 1 video about B-58
https://vimeo.com/45996409
Armadillo1
Re: 6 wheel bogey
Wed Nov 29, 2017 2:43 pm
The answer is: this is one disk with 2 tyres
Balerit
Re: 6 wheel bogey
Wed Nov 29, 2017 7:50 pm
It's like the double wheels on a 'horse and trailer or as the Yanks call them semi's' , the rims seem to be bolted together.
Users browsing this forum: AIRWALK and 14 guests
