- Flap deployment
Landing gear deployment
Reverse thrust deployment
It is conceivable that such functions may one day be fully or partially automated?
Faro
Flow2706 wrote:There are many factors involved that the automation can not "know"... ...Or recently we planed to fly a RNAV Approach into one airport - apparently there was some database error which resulted in the computation of a totally incorrect vertical profile, so we also had to intervene and use selected vertical guidance.
Flow2706 wrote:There are many factors involved that the automation can not "know". Maybe you are slightly fast on the approach and want to get the speed down - you would probably extend the flaps just below the limit speed to generate additional drag to help the aircraft to slow down (or possibly you want to give yourself some margin to limits in very bumpy conditions and therefore extend the flaps at a different speed). This is even more true about reversers - possibly you plan to leave the runway at the end to reduce taxi time and therefore you will only need reverse idle or for noise abatement. Also, automation is not always correct (or can not cope with a situation) and has to be monitored closely. Recently we started our descend into Munich from FL360 just to experience a massive wind shift on the way down - if we did not intervene by downgrading the automation from managed mode (DES) to selected (in this case vertical Speed +-0 for a short while to keep the speed trend under control) we would probably ended up in an overspeed condition. Or recently we planed to fly a RNAV Approach into one airport - apparently there was some database error which resulted in the computation of a totally incorrect vertical profile, so we also had to intervene and use selected vertical guidance.
Classa64 wrote:Is Auto braking a hybrid of Automation and pilot input then... If Auto brakes are set to 2 on a 777 and its not enough can you just push on them harder?
rjsampson wrote:Unless decades from now, should airlines make it SOP and lose sufficient trust in their pilots to land their equipment, and decide automate all landings: You're not going to see that level of automation. And all airports would need to be equipped with CAT-III ILS systems (or advanced WAAS, or whatever it could be).
Which actually brings me to a question: When doing a CAT-III autoland: Are those functions even automated? (Flaps, gear, etc.)?
