titanmiller
Largest aircraft design without hydraulic flight controls?
Mon Dec 04, 2017 11:15 pm
Any idea on what the largest historic aircraft without hydraulic flight controls is? I know that the 707 used aerodynamically controlled flight controls. Anything bigger/heavier?
workhorse
Re: Largest aircraft design without hydraulic flight controls?
Mon Dec 04, 2017 11:53 pm
The Il-62 must be a good contender.
irelayer
Tue Dec 05, 2017 2:34 am
I believe the IL-62 was the largest and heaviest mass-produced commercial aircraft without hydraulic flight controls...
mmo
Tue Dec 05, 2017 1:45 pm
The B-52D has no hydraulic powered flight controls.
Apprentice
Wed Dec 06, 2017 3:44 pm
Hi: In fact Ilushin used a Self Contained Hydraulic System (ARM-62) to power a/c Rudder.
In case of hydraulic lock, You may disconnect system by operating a switch that fired a cartridge that disconnect a link. Them You must continue flying manual.
For Il-86/Il-96, 3 an "ARMs" are used, with one each added to Roll and Pitch channels
“An AME, with just a Mechanic Role”, as per one of our pilots
"A NO" is a positive answer., "DON'T KNOW" is not. My Tutor (a wise man)
“CUBANA” 90 years Flying”
irelayer
Wed Dec 06, 2017 5:43 pm
Interesting I didn't know this. Thanks for sharing!
-IR
LH707330
Thu Dec 07, 2017 3:51 am
The 707s with the tall fin had a similar system. The short-finned 707-300 did not have a powered rudder, though, so that may be the largest fully-mechanical airliner.
http://www.adastron.com/707/qantas/Q-bellows.htm
Users browsing this forum: FlyHappy, Google Adsense [Bot] and 11 guests
