ojjunior
Doubt: Reversing on taxiway?
Thu Dec 21, 2017 3:52 pm
I was looking at this classic pic and came across something that I can not identify; perhaps smarter friends here will.
Well, I see thrust reverses applied and braking smokes on the mains but... isn't it a taxiway???
Or back in 92 LHR's main runways looked like this?
Please help me on this.
Thank you.
77west
Re: Doubt: Reversing on taxiway?
Fri Dec 22, 2017 5:59 am
Looks more like dust kicked up from the reversers, not brake smoke. But yes, the runway appears to be to the left of the plane. Stange.
77West - AW109S - BE90 - JS31 - B1900 - Q300 - ATR72 - DC9-30 - MD80 - B733 - A320 - B738 - A300-B4 - B773 - B77W
paullam
Fri Dec 22, 2017 7:04 am
It doesn’t happen often but it’s not uncommon to use idle reverse on taxiways going downhill in order to prevent the wheel brakes from getting too hot. I’ve seen it plenty of times on biz jets but also on A320 etc., for instance in AMS on that taxiway leading to the Polderbaan.
712 733 734 735 737 738 744 752 763 77E 77L 77W 788 789 | A20N 318 319 320 321 332 333 343 346 388 | ASK21 | AT75 AT76 | BCS3 | C152 C172 C182 C210 | CR2 CR7 | DH8C DH8D | E190 | F70 F100 | LJ24 | PA31 | RJ85 RJ1H | SF34 | SU9 | YK2
mmo
Fri Dec 22, 2017 8:23 am
Interesting, as the FCOM prohibits the use of reverse to slow the aircraft while taxiing on both the 320 and 400.
barney captain
Fri Dec 22, 2017 8:48 am
It looks like the spoilers are also deployed.....
Southeast Of Disorder
paullam
Fri Dec 22, 2017 8:55 am
Even idle reverse?
AirKevin
Fri Dec 22, 2017 9:27 am
Is it possible that they automatically deploy once the reversers are deployed?
Captain Kevin
Leej
Fri Dec 22, 2017 10:54 am
Interesting photo. To my eye it looks like she is taxiing at the eastern end (northside) of 27L (or whatever designation then). You can see the spire of St Paul's Church near Hampton in the distance, so view is looking SSE and probably taken from the now demolished Queens Building. Could she have been taxiing from the maintenance base to the terminal with a little check of systems on the way? Did Varig use T4 or T3 back then?
mmo
Fri Dec 22, 2017 11:42 am
paullam wrote:
Even idle reverse?
Yes, even with idle reverse. The preferred method is to apply one brake application to bring the aircraft to a very slow speed, release and then let the aircraft gain speed. Repeat as necessary. "Riding" the brakes will increase the brake temps much more than the recommended technique of a brake application.
BravoOne
Fri Dec 22, 2017 2:06 pm
Not uncommon on the Gulfstrean when during taxi, especially when light. Also was common on the 727 center engine but as I recall when your were in reverse you were blocking the air for the CSD oil cooler so extanded periods were discouraged.
arcticcruiser
Fri Dec 22, 2017 4:51 pm
Nothing in the 757/767 manuals prohibits using reverse idle during taxi to keep speed in check or if taxiway is slippery.
Fri Dec 22, 2017 5:37 pm
Might be on the old runway 23
bananaboy
Fri Dec 22, 2017 6:27 pm
That's what I think. It looks like the flaps are extended to quite an extent suggesting a landing.
The photo in the database states it had landed.
There are other photos of aircraft landing on 23 taken at Heathrow on that day.
http://www.airliners.net/search?country ... lay=detail
ojjunior
Tue Dec 26, 2017 10:08 am
Thank you all
But that's a damn taxiway looking runway then, isn't it?
bananaboy
Tue Dec 26, 2017 11:49 am
Thank you all
Haha indeed! It wasn't used very often used as a runway as it messed up movements on the other runways. It also required BA to move their aircraft parked at the far end of runway 23 that were awaiting gates at T4. Others here will know much more about operations on runway 23 when it existed.
Tue Dec 26, 2017 1:43 pm
ojjunior wrote:
Thank you all
It is disappointing to see the photo caption had said it just landed on 23.
From the photo caption
“RG758 from Rio and Sao Paulo with thrust reversers deployed after landing on RWY23. DD 01.06.92. RT ILFC as N791LF 20.09.94. LT Garuda as PK-GSI 03.95”
ojjunior
Tue Dec 26, 2017 2:41 pm
Very interesting your perspective ... does it mean then that aircraft that land do not use taxiways afterwards? I am referring to the scene I see in the photo, sorry if this offends your vast wisdom.
Tue Dec 26, 2017 3:27 pm
It would have been more useful for you to provide all the information you had available whe you made your initial post, we could have provided you with what RW23 looked like.
GalaxyFlyer
Tue Dec 26, 2017 4:01 pm
I was the F/E on a EA 727 once when we backed up about 300’ on the Inner at BOS (might have bern the Outer in front of the main terminal). ATC or the yoke actuators goofed and got us nose to nose with an outbound L1011. We deferred to his size and backed up. Cappy asked th3 F/O and I, asked the Ground for clearance to the rear and away we went. Of course, power backs were common then.
GF
vikkyvik
Tue Dec 26, 2017 5:43 pm
You can see white edge lines, which is what makes me think it's a runway.
BoeingGuy
Sat Dec 30, 2017 8:19 am
Yes, on Boeing airplanes there is an interlock that will deploy the speed brakes when the thrust reverser levers are raised.
BoeingGuy
Sat Dec 30, 2017 8:22 am
That’s not true for Boeing airplanes unless a customer has adopted that policy. The FAA approved AFM prohibits backing the airplane using reverse thrust on the 747, 767, 777, and 787 (but it’s not prohibited for the 737 or 757). Says nothing about slowing the airplane on a taxiway.
Sat Dec 30, 2017 9:44 am
It is prohibited on some 757s, need to check the AFM for the model and engine.
BoeingGuy
Sat Dec 30, 2017 4:59 pm
I checked years ago and it wasn’t prohibited in the 757 AFM I looked in, but didn’t check all combos like you state. AA experimented with it at DFW many years ago and they have RR engines. Britannia had a 757 power back procedure in their own 757 FCOM, but I don’t know if they ever did it.
Not only did AA quickly decide it wasn’t a good idea, I was told that they couldn’t get the airplane moving backwards at high gross weights.
Balerit
Wed Jan 03, 2018 6:50 am
The fact that the spoilers are raised and the flaps are deployed, shows that it is landing. By the way the spoilers will only auto deploy if the lever is lifted out of it's detent (armed). The puff of smoke from the nose gear (seen near the main gear) is an indicator as well.
Licensed Aircraft Maintenance Engineer (retired).
BoeingGuy
Wed Jan 03, 2018 4:01 pm
That's not completely correct on Boeing airplanes. The spoilers will deploy when the airplane is on the ground if the Thrust Reverser Lever(s) are raised, regardless of whether the Speedbrake lever is armed.
The Speedbrakes will only auto deploy on touchdown if the level is armed and thrust levers are at idle.
tjwgrr
Wed Jan 03, 2018 4:16 pm
Yeah, we have a nest of G-Vs here in GRR- see it all the time. I've seen Citation 750s do it occasionally as well.
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
PowerliftDrsTX
Thu Jan 04, 2018 2:10 pm
Many of the jets I have flown have automation that automatically deploys (sometimes half of) the spoilers when wheelspeed hits a certain number and thrust levers are at idle. The automation assumes you want to slow down and the boards come up.
I also echo the "brake cooling" comments but I know nothing of the 74 limitations on TR usage during taxi.
Users browsing this forum: Boair, gabep, jetwet1 and 10 guests
