aero654
ATR PW127 engine starter generator
Wed Jan 03, 2018 8:44 am
Hello everyone,
Is there someone out there who can give me an idea where I can find an approved technical data for the starter/generator installed on an ATR 42/72 -500 PW127 series engine
I would like to know how much continuous current that the ATR PW 127 engine starter/generator is drawing during starting. The reason behind is I am looking for possibilities to use a series-parallel automobile battery as DC GPU for ATR 42/72 aircraft that can be used for starting.
Thanks and regards
Aero654
WIederling
Re: ATR PW127 engine starter generator
Wed Jan 03, 2018 9:10 am
Look at the onboard battery capabilities?
i.e. what is installed?
Murphy is an optimist
VSMUT
Wed Jan 03, 2018 12:24 pm
FCOM 2.02.05 page 1, Use of a weak DC GPU:
"...a steady current of 300 - 400 amp under 28 volts to insure correct functioning of all electrical services prior to startup.
For engine start, the GPU must be able to provide additional starter current of 1000 Amp while keeping more than 12 volts (ie 16 KW instantaneous power)."
WIederling
Wed Jan 03, 2018 2:43 pm
what duration?
using automotive batteries ( 2 * 12V in series ) you'll never get 28V. Best you will see is 25V under load.
starting is easier. Look for the CA/@0°C ( or CCA/@-15°C) value ~1400A ( allows 30s load with voltage per 12V unit not below 7.5V )
1400A is what a regular 180Ah battery will provide as CCA current. If you are doing a dedicated purchase you may look into traction cells to get to 28V
VSMUT
Wed Jan 03, 2018 9:37 pm
what duration?
Pretty sure it was 30 seconds, but I will have to check.
Users browsing this forum: fr8mech, pikachu and 22 guests
