jonair8
SNA Noise Abatement Procedure
Sat Feb 03, 2018 7:29 am
I recently flew on a Compass E75 out of SNA. I was excited like always to experience the usual SNA takeoff but to my surprise and disappointment, no noise abatement procedure was done. I've had several flights out of SNA on other airlines/aircraft so I knew what to expect from a passenger perspective. I just have not been on CP out of SNA. After doing a search on here, I've read a lot of previous discussions about the noise abatement procedure, although a lot of these discussions are older. Was wondering if it was possible for an airline to have a waiver to the noise abatement procedure? The Embraer 175 is a reasonably quiet aircraft, and I'm expecting some newer aircraft are quieter to the point where if they climbed normally instead of doing the SNA noise abatement, the amount of noise produced would be roughly the same either way. It's hard to believe that the crew would simply just forget to follow it.
a320fan
Re: SNA Noise Abatement Procedure
Sat Feb 03, 2018 7:39 am
I believe it’s been pretty much a standard departure for quite a few years now.
A319, A320, A321, A330-200, A380, 737-700, 737-800, 777-200ER, 777-300, 777-300ER, 787-8, Q300
BoeingGuy
Sat Feb 03, 2018 4:13 pm
The 737-700 and -800 don’t have to do the special noise abatement procedure anymore either.
It’s just a standard takeoff profile. I think the 757 is the only model that still does it. Delta flies a few in there a day, but that’s it.
Unfortunately, the special takeoff procedure is pretty much a thing of the past. I like it on the AS 737-400s. That was fun. Even when they did it on the -700, it was pretty benign.
BravoOne
Sat Feb 03, 2018 5:21 pm
They are pretty hard ovrt on the noise abatement issue down in SNA,I recall asking if we could land there in a corporate 757 and the answer was "No Way". They wouldn't even let a 737 BBJ in there at the time.
jetero
Sat Feb 03, 2018 5:22 pm
That’s because the FBOs have nowhere to park them, not because of the noise abatement procedures.
BravoOne
Sat Feb 03, 2018 5:59 pm
You maybe correct regarding the space for parking over night but that was not the reason given. I might add there is always room for parking if the price is high enough. Witness, Niece, France where I have parked for seven days and had a fee for over $90,000/
Web500sjc
Sat Feb 03, 2018 6:08 pm
I think the only aircraft that do the old, full on noise abatement procedure are the MD-88/90 (if they ever go there) and the A300 (fedex 5 days a week).the 757 has a modified noise abatement procedure, but not a full on cutback like the A300.
Boiler Up!
BoeingGuy
Sat Feb 03, 2018 8:42 pm
The 757 has it programmed into the Autothrottle. There is a formula they use that is the same as all other models that do it. The cutback thrust is such that if an engine fails, you have to maintain a 1.2% climb gradient at that thrust on one engine.
vikkyvik
Sat Feb 03, 2018 9:51 pm
And honestly, it doesn't feel much different to any normal takeoff. The only thing noticeable was holding the brakes while the engines spooled up. After that, takeoff and climbout felt totally normal from a passenger perspective. (I flew DL's 757 out of SNA a couple months ago).
barney captain
Sat Feb 03, 2018 10:19 pm
Not at WN.
Noise abatement profile on every takeoff, every day.
Hold brakes, 45% N1, release brakes, max thrust, climb at V2+15 to 800' AGL, reduce to cut-back thrust, hold V2+15 to 3000' AGL, normal climb thrust, retract flaps on speed. Usually a flaps 10 takeoff in the -700.
Southeast Of Disorder
barney captain
See above.
BoeingGuy
Sat Feb 03, 2018 10:37 pm
See above.
To my knowledge no other airline does the cutback on the 737NG. Not AS, AA, UA, or DL. I’ve been a passenger on AS several times and it was clearly a normal profile. Why does WN still do it?
barney captain
Sat Feb 03, 2018 10:38 pm
See above.
Great question and I think you're right - it's just WN. I think it has something to do with the number of flights we have there (a bunch) and total noise signature.
Alias1024
Sat Feb 03, 2018 11:40 pm
Delta still flies noise abatement profiles at SNA.
BoeingGuy
Sun Feb 04, 2018 12:23 am
With the 717 and 737-700? I don’t think so.
Alias1024
Sun Feb 04, 2018 12:39 am
They do. It’s pretty much your regular ICAO NADP-1 noise abatement profile. Cutback at 800/1000 with acceleration height of 3000.
BoeingGuy
Sun Feb 04, 2018 1:01 am
Not to my understanding. The 717, 737-700, 737-800 and some regional jets have FAA approval to fly a normal takeoff profile from SNA.
Redbellyguppy
Sun Feb 04, 2018 8:52 am
Some of it has to do with what category noise slot you are using too. Some of the slots my airline, SWA, uses are the most stringent ones so our company blanket policy is that all flights do the cutback to guarantee compliance.
barney captain
Sun Feb 04, 2018 10:36 am
Great insight Red, thanks!
BravoOne
Sun Feb 04, 2018 1:40 pm
Have to chuckle as several years ago we landed at LGB around 2100 in the evening. We used very trick in the book to keep this 767-200ER (JT9D's) quiet but we still rang the bell and got a letter for the Noise officials. When I spoke them on the phone a week or so later the guy said "you could have shutdown both engines and glided in" but you were still going to ring the bell with that airplane. Obviously he was trying to be funny, but I got his drift ans we never went back to LGB.
Alias1024
Sun Feb 04, 2018 4:56 pm
Regardless of that approval, Delta still uses noise abatement profiles for all fleets at SNA.
You can add SkyWest CRJ-700s (flew them for years) and Horizon E175s (rode one yesterday out of SNA) to the list of aircraft that fly noise abatement profiles.
BravoOne
Sun Feb 04, 2018 6:37 pm
Going to show my ignorance here but why would the FAA be asserting it's approval for a Normal takeoff profile? Aren't these noise restrictions imposed by the locals with some FAA oversight. The Newport Beach back bay community is very vocal and has in the past shown a very pro active noise program but if it works without a NADP procedure, it's just another takeoff?
BoeingGuy
Sun Feb 04, 2018 7:29 pm
Because some models of airplanes such as the 737-800s can meet the noise requirements without doing a special procedure.
BravoOne
Sun Feb 04, 2018 8:39 pm
Okay I see where you're coming from now. Is this something that is reflected in the AFM?
Web500sjc
Sun Feb 04, 2018 9:26 pm
I think all the airplanes use a noise abatement profile at SNA, but it’s the “standard noise abatement profile” (NADP-1/ NADP-2)... not the severe noise abatement profile of the past where power was drastically reduced. Now it’s a reduction to normal climb power, and a continued climb with delayed flap retraction. Much more maundane and less severe.
Boiler Up!
barney captain
Mon Feb 05, 2018 8:51 am
Again, not at WN. Our cutback N1 is significant - usually in the mid 70%, with normal climb N1 closer to 90%.
BoeingGuy
Mon Feb 05, 2018 11:35 pm
You guys still do a full static engine run-up too, don't you?
A few years ago an AA pilot posted their SNA procedures for for the 738, 757, and MD-80. He confirmed that the 737-800 does neither a static run-up or any cutback other than normal takeoff profile. When I've flown AS out of there, it has been just a normal profile with normal thrust reduction.
As someone stated though, WN may have some different noise slots.
barney captain
Tue Feb 06, 2018 2:46 am
No, only to @ 45% N1 or so. We used to go all the way to the cutback N1 (75%-ish) before releasing the brakes, but no longer. We also used to every takeoff bleeds off as well, but it hasn't been that way in a long time. The procedure has gradually been modified and slightly relaxed over the years.
BoeingGuy
Tue Feb 06, 2018 3:37 am
That's pretty normal run-up isn't it? For example, everyday procedure on a GE 777 is to release brakes, stabilize at about 55% N1 and then push TO/GA.
I haven't seen the static run up since flying out of SNA on a AS 737-400. That was a nice jolt back into the seat.
I was told that AA changed their procedure for 757 to stop doing the static run up in about 2001. So like you said, it's been relaxed.
barney captain
Tue Feb 06, 2018 5:43 am
It's a fairly normal spool-up, with the exception of the holding of the brakes. You definitely feel it as you apply max takeoff thrust while simultaneously releasing the brakes.
Users browsing this forum: fadecfault and 18 guests
