canyonblue17
Flight time difference from NYC to KEF
Mon Feb 05, 2018 5:27 am
I am sure I am missing something - but I have been checking the flight times of Delta, Icelandair and Wow Air on their routes from the JFK/EWR to KEF and have found a substantial difference in flight time recently. While Icelandair and Delta have been making the Eastbound journey in just under 5 hours, the Wow flights have been taking just under 7 hours. The distances have all been roughly the same at around 2600 miles. I know we are talking 757s and 767s versus the A321s ...but is there that big a difference?? Thoughts from those smarter than me....(that means you). Thanks
negative ghostrider the pattern is full
asuflyer
Re: Flight time difference from NYC to KEF
Mon Feb 05, 2018 5:44 am
WOW does not have ETOPS unlike DL and FI so they are restricted to flying on routes closer to land.
canyonblue17
Mon Feb 05, 2018 6:20 am
Did not know about the ETOPs - you would assume an airline doing plenty of transatlantic flying would be ETOP certified. But the odd thing is the travel distance between the airlines is still very small - 200-300 miles at best - so that shouldn’t account for a 2-hour difference??
gunsontheroof
The jet stream has been in overdrive over the North Atlantic on several occasions recently.
http://www.dailymail.co.uk/travel/trave ... ecord.html
Picked a hell of a week to quit sniffing glue.
JRL3289
Mon Feb 05, 2018 6:37 am
On 2 February Icelandair took over 6 hours to fly JFK-KEF with a B767 while Delta was 4 hours and 45 minutes with a 757.
Is ETOPS really the explanation? Icelandair's 767s are ETOPS, no? Jet stream is not a reason given we're talking about flights operating on the same day.
arcticcruiser
Mon Feb 05, 2018 6:43 am
I am quite sure you missed something there. Are you quoting air times or block times? Or both?
canyonblue17
Mon Feb 05, 2018 7:31 am
I was finding the same thing - just with different carriers. And the info was from the same website in the same day and basically the same route. And the times I was comparing were for completed trips.
LoftleidirDC8
Mon Feb 05, 2018 7:48 am
Could it be that WW simply coasted along at a lower speed letting the jet stream keep the same stage length while DL/FI kept the same speed and caught up the time?
Virginblue4
Mon Feb 05, 2018 8:05 am
Using the flightradar24 playback feature, both the Icelandair and the Delta flights on February 2nd took 4 hours and 30 minutes from the moment of take off to the moment of landing (give or take a few minutes due to the fiddly scrubbing controls within the app).
712 738 744 752 762 763 764 320 321 332 F70 Q400
BE BY DL MT PC V7 VS WA ZB 6Y
SRQKEF
Mon Feb 05, 2018 8:56 am
FI was 6 hrs gate to gate due to FI614 departing during the European rush hour at JFK, while DL leaves much later in the evening and thus could head straight out to the runway. Time airborne was similar.
Users browsing this forum: Starlionblue, theabbiss and 10 guests
