zzaewon
IDG issue/A320, CFM56 series
Mon Feb 05, 2018 6:18 pm
Hello,
I've been researching an IDG failures, which occurs last couple of years since this has shown the level of alert as reliability standpoint. One of my Powerplant colleagues told me that we'd better trace possible symptoms in the APU, case of the IDG failures. In terms of supplying a sufficient amount of electronic power to the aircraft, somewhat this makes sense but I am still wondering why and the any legitimate reasons to expand work scope to the APU.
Any thoughts, thanks!
Lpbri
Re: IDG issue/A320, CFM56 series
Mon Feb 05, 2018 11:11 pm
Hmmmm. Not sure what your asking. APUs don't have IDGs, since the turn at constant speed. Not sure there is any connection between the APU performance and the engine IDG. Not aware of any IDG issues on the CFM56 either.
Apprentice
Tue Feb 06, 2018 1:20 am
Hi: If about Power fluctuation, IDG is powered by 28 vdc...
Must of the times, IDG fluctuations may be traced for incorrect IDG’s Oil Service, to low or to high, because not enough keeping drain hose installed after service for some time, or just lack of oil.
Slds
“An AME, with just a Mechanic Role”, as per one of our pilots
"A NO" is a positive answer., "DON'T KNOW" is not. My Tutor (a wise man)
zzaewon
Tue Feb 06, 2018 6:15 am
Lpbri & Apprentice,
Thanks for the your reply. That was what I was thinking about and I am on-board with your opinions.
fr8mech
Tue Feb 06, 2018 5:58 pm
Not sure about the A320, but a problematic APU generator on an MD11 can wreak havoc on the electrical system. I've seen it cause individual busses trip off and look just like an IDG failing. Takes a while to isolate unless you get lucky and are able to decipher the captured EPCU alerts, if there are any.
When seconds count...the authorities are minutes away.
Users browsing this forum: airportugal310, FrmrKSEngr, PITingres and 9 guests
