Apprentice
Preferred Engine
Wed Feb 07, 2018 2:37 pm
Hello: I would like to know which Engine’s type would You, Mechanic, preferr to work on (Line, Base).
In my practice, beside servicing oil which is not a big deal, my preferrence are, due to high dependability, easiest to access to core part and to replace parts, is needed.
1. GE
2. PW
3. RR
Rgds/ Apprentice
“An4; IL18; IL6; Tu5; D10; MD11; MD83; B32; B34: B37; B744; B748; B752; B763; B772; B773; B77W; A320; A332; A333; A342; A343.
"A NO" is a positive answer., "DON'T KNOW" is not. My Tutor (a wise man)
“CUBANA” 90 years Flying”
StereoTechque
Re: Preferred Engine
Fri Feb 09, 2018 1:36 pm
Maintenance wise I think you can never go wrong on a CFM..
Looking California.. Feeling Minnesota.... R. I.P. Chris Cornell...
IFixPlanes
Sat Feb 10, 2018 12:52 pm
PW on position 2?
You possibly have never worked on a PW1100G! :shakehead:
never tell an engineer he is wrong ;-)
Apprentice
Sat Feb 10, 2018 7:37 pm
IFixPlanes wrote:
PW on position 2?
You are right. I had never working suc “pretty”
benbeny
Sun Feb 11, 2018 12:16 pm
What makes CFM idiot-proof?
Dalmd88
Sun Feb 11, 2018 2:09 pm
From working the Line I would have to go with the CFM56. On the 737NG no ladders required. During an A check there is relatively little work compared to other types. Fan balance is real easy, the onboard box tells you what to do and is usually right the after the initial spin. About the only negatives I had were; takes a lot of oil, cowl open up sucks, and changing the fuel control thingy (HMU?) sucked.
Users browsing this forum: glen and 69 guests
