wannaflybaby
Rodents (mice, rat, cockroaches) handling on an aircraft
Thu Mar 01, 2018 10:47 am
is there any information, journal, cite, or manuals for me about finding an rodents on an aircraft?
it's important for me to complete my study, thanks
Re: Rodents (mice, rat, cockroaches) handling on an aircraft
Thu Mar 01, 2018 2:17 pm
I think you need to expand more in your post to explain in more detail what you are seeking.
flyingturtle
Thu Mar 01, 2018 4:16 pm
Crew: "Mouse found in cockpit."
Maintenance: "Cat installed."
And I second the comment by zeke.
David
JAGflyer
Thu Mar 01, 2018 9:38 pm
Boeing AFAIK does have a procedure in their maintenance manuals for removal of vermin/rodents. The methods I have heard range from applying poison at the seat(s) where bugs were spotted at a minimum all the way to a full fumigation of the aircraft over several hours to kill anything present inside the aircraft at the extreme. The airline I work for operates extensively to the Caribbean and we've had reports of bugs, small lizards, and mice on the aircraft from time to time.
If you flew today, thank a Flight Dispatcher!
RetiredWeasel
Thu Mar 01, 2018 9:44 pm
The State of Hawaii Ag Dept? use to inspect aircraft arriving from Guam for brown tree snakes. The snake free state actually found a few from what I heard. Unsure if they still do that.
Max Q
Fri Mar 02, 2018 1:50 am
Rodents are an issue on aircraft occasionally although not as big a
problem as ships have lived with for
hundreds of years !
A rat was spotted on one of our 767’s
a few years ago
Since it couldn’t be ‘tracked down’ the aircraft was taken out of service, sealed
up and fumigated
Don’t know if they found the offender
but there were no more sightings..
MatthewDB
Fri Mar 02, 2018 2:55 am
Fly it to North Dakota in the winter, drain the water and leave it for the night. Any vermin will be dead in the morning.
CCGPV
Fri Mar 02, 2018 3:04 am
I've been on flights in Africa where maintenance crews spray an unknown chemical down the isles with passengers in the seats. Happened in Senegal and South Africa.
That always worried me.
Stay curious
SAAFNAV
Fri Mar 02, 2018 7:39 am
What worries you?
It's not an unknown chemical, it is permethrin.
The WHO requires disinfection of aircraft coming from areas with insect-borne infectious diseases like malaria and Zika fever. Those illnesses worry me quite a bit more than what's in the bottle.
wannaflybaby
Fri Mar 02, 2018 9:35 am
what i wanna search is can all of you explain to me is there any procedures to do fumigation, or rodent handling, cause i've been search it on the google but not found it..
i search the literature, or some kind of procedure of that kind of maintenance
is that procedure is handled by AME? or handled by third party (i.e pest control company)
thanksss
fr8mech
Fri Mar 02, 2018 10:57 am
thanksss
We have a third-party handle it with maintenance oversight.
The procedure is contained in our general maintenance manual. None of our AMM's contain any information concerning pest removal.
When seconds count...the authorities are minutes away.
wannaflybaby
Fri Mar 02, 2018 4:03 pm
fr8mech wrote:
thanksss
can i have that copied of your general maint manual sir?
i wanna to make that for my studies on rodent on aircraft analyses
thankss
frmrCapCadet
Fri Mar 02, 2018 4:41 pm
There are trained and licensed pest control companies and people who specialize. I am sure that every airline/airport has contracts with companies. And the people who work on planes may not be the people who work in other parts of the airport. There are less obvious and more effective ways of using permethrin than as mentioned above.
larshjort
Fri Mar 02, 2018 4:46 pm
I worked for a scandinavian airline that had wetleased an aircraft to a west african airline. It went without a hitch for the 6 months the contract lasted. However on the first leg of the flight home the FO spots a rather large spider in the cockpit and they decide to return. The aircraft was fumigated and they flew home again.
When we did an A check afterwards, most weren't too happy about it and the unlucky guy who got the cockpit was pretty mad at us when he found the plastic spider we had placed in there.
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
CCGPV
Fri Mar 02, 2018 7:00 pm
What worries you?
Permethrin is pretty bad stuff around pets and the like. I treat lots of things with it and take much more precautions (as indicated to do so by the MSDS) than the airlines did.
Stay curious
Fri Mar 02, 2018 9:55 pm
thanksss
Search aircraft fumigation should give some results.
For Airbus aircraft the process is in the aircraft maintenance manual. They used to use SOXAL PESTIGAS 15-20 years ago, now the just use CO2 for rodents and reptiles.
Common insecticide is often used first as roaches lay their eggs before passing. Between 750-2500 kg (depending on the size of the aircraft) of CO2 is put into the cabin for up to 12 hrs.
Cabin seats can be treated with hot air or steam to get rid of crabs.
fr8mech
Sat Mar 03, 2018 1:23 am
No, you can not. It's an internal document. It basically says the what I wrote.
Aircraft maintenance management is responsible to ensure that adequate steps have been taken to address the bug/pest infestation. If unable to confirm the elimination of the pest, further action may be deferred to re-check the aircraft at a later time. If an outside vendor is used, aircraft maintenance management retains the responsibility to ensure elimination of the pest.
7673mech
Sun Mar 04, 2018 10:29 pm
We contract out fumigation for bugs and take care of rodents ourselves.
Typically set traps for a minimum of eight hours closing of doors. Put traps in very specific areas.
BaconButty
Mon Mar 05, 2018 10:02 pm
I take it you're referring to the kind of crab infestation you might see on a flight back from Magaluf, rather than, say, Male?
Down with that sort of thing!
Users browsing this forum: WesternDC6B, zaphod42 and 11 guests
